Is Kinetic Energy Direction-Dependent?
  • Thread starter Thread starter BuBbLeS01
    Physics
The discussion revolves around the concept of kinetic energy and its dependence on various factors, including direction and reference frames. Participants are evaluating a series of statements related to kinetic energy and work done in different scenarios.
  • Participants are assessing the correctness of statements regarding kinetic energy, questioning whether it can be negative and if it is direction-dependent. There is a focus on the implications of these concepts in real-world scenarios.
Some participants express uncertainty about their evaluations of the statements, particularly regarding the directionality of kinetic energy. There is an exploration of the implications of kinetic energy being independent of direction, with some guidance offered on the nature of energy and its measurement.
Participants are working within the constraints of a homework assignment that requires them to determine the correctness of specific statements without providing complete solutions. There is an emphasis on understanding the underlying principles rather than simply confirming answers.
BuBbLeS01
For each of the following statements determine whether it is correct or incorrect.
A.The work done to raise a box onto a platform depends on how fast it is raised.
B.The kinetic energy is independent of the reference frame of the observer.
C.The kinetic energy of an object depends on the direction of the motion involved.
D.The kinetic energy can never be negative.
E.Spring A and B are identical except that A is stiffer than B; that is kA > kB. More work must be expended on spring A if both springs are stretched by the same amount.
F.If the Earth revolves around the sun in a perfectly circular orbit, then the sun does work on the Earth.
A.Incorrect.
B.Incorrect.
C.Correct.
D.Correct.
E.Correct.
F.Incorrect.
Which one(s) are wrong?? I thought I had them right but I don't.
A.Incorrect.
B.Incorrect.
C.Correct.
D.Correct.
E.Correct.
F.Incorrect.
C is wrong.
Kinetic Energy can never be negative, so does it matter in which direction the object is moving?
oooo duh lol.
If kinetic energy depended on direction, then if it went in the opposite direction of the 'positive vector', it would be negative which is not possible.
There is no definite positive vector. Kinetic energy is energy. If energy was lost by dropping an object from a height because the positive direction for kinetic energy was diagonal to the ground, then it would generally mean that by changing the direction, you are somehow creating heat.
Anyway, in real life, how would one specify in what direction the kinetic energy SHOULD be going?
No, it does not matter which direction the object is moving.
21K
