Calculate Acceleration of 2.0kg Block w/ Pulleys & Blocks
  • Thread starter Thread starter Grapz
    Blocks Pulleys
The acceleration of a 2.0 kg block on a frictionless table, connected to a 1.0 kg block via a massless string and pulley system, is calculated to be 3.27 m/s². The system operates under the principles of Newton's laws, where the tension in the string remains constant due to its massless nature. The forces acting on both blocks are analyzed through free body diagrams, leading to the conclusion that the acceleration of the two blocks is related by the equation a1 = 2 a2, where a1 is the acceleration of the 1.0 kg block and a2 is that of the 2.0 kg block.
  • Understanding of Newton's laws of motion
  • Knowledge of free body diagrams
  • Familiarity with massless string and pulley systems
  • Basic algebra for solving equations
  • Study the principles of Newton's second law (F = ma) in detail
  • Learn how to construct and analyze free body diagrams for complex systems
  • Explore the dynamics of massless pulleys and their applications in physics
  • Investigate the relationship between tension and acceleration in connected systems
This discussion is beneficial for physics students, educators, and anyone interested in understanding mechanics, particularly in analyzing systems involving pulleys and blocks.
Grapz
What is the acceleration of the 2.0 kg block across the frictionless table
http://s167.photobucket.com/albums/u143/grapz720/?action=view&current=phy.jpg
I know the acceleration is positive for one block and negative for the other.
F= ma , also tension in the string should be the same through out
Okay. Well, I originally believed that there would be no acceleration. But i don't understand how there could be an acceleration. The answer says there is an acceleration of 3.27 m/s^2. How can a 1 kg accelerate a 2kg on a flat surface??
And the string is supposed attached to a wall, so how can this system even move.
Can someone help explain this problem and how to tackle it . thanks
Basically, you have block of mass m1 = 1.0 kg that is attached to a massless, ideal string. This string wraps around a massless pulley and then wraps around a second pulley that is attached to a block of mass m2 = 2.0 kg that is free to slide on a frictionless table. The string is firmly anchored to a wall and the whole system is frictionless.
1. m2 can move freely on the frictionless table because the pulley that wraps the string from the wall to m2 is "glued" onto m2. Since m1 is under the control of gravity and that m1 and m2 are connected via the string, m2 will move to the right.
2. Drawing a free body diagram for m2, you have 2 tension forces (T) in the positive x direction and one positive normal force (n), and one negative weight force (w)
Thus Fnetx= 2T = m_2*a_2 (the two Ts are equal in magnitude because you have massless string and by Newton's 3rd Law you know that the force exerted from the wall via the string onto m2 is the same as the force exerted by m1 via the string onto m2 ***notice that I'm only worried about forces exerted onto m2).
ok, so we know that T = (m_2*a_2)/(2)
We only need to worry about Fnetx and not Fnety because the block only moves in the z direction, thus it only has force in the x direction.
3. Drawing a force body diagram for m_1, we know that there is a T in the positive y and a w force in the negative y. Thus we only need to worry about Fnety.
Fnety = T-w_1 = T-m_1*g = m_1 * a_1
Notice again, that the T is the same T as exerted onto m_2 by the wall and by m_1. Now, its the tension exerted onto m_1 by m_2, via the string.
Force_wall onto m2 = Force_m1 onto m2 = Force_m2 onto m1 This is all true because of the massless string and massless pulley
Ok, back to Fnety. Solve for a1 and you get a_1 = (T-m_1*g)/(-m_1).
Let's define y_1(t) and x_2(t) as the vertical coordinate of the block of mass m_1 and the horizontal coordinate of the block of mass m_2 , respectively. Let's also define L as the length of string. Thus L = 2x_2(t) + 1y_1(t) + C (C is some constant that accounts for the length of string from the wall to the start of table). Okay, if you differentiate 2x to get to acceleration, you know that a1 = 2 a2.
So now you have a way to relate T, a_2, and a_1. You can solve for anything.
Hope this helps!
BTW, this was my very first post using PF. Thanks!
  • · Replies 52 ·
