Voltage Drop Across Transmission Lines
The discussion focuses on calculating the voltage drop across a pair of power transmission lines with a resistance of 0.850 Ω each, carrying a current of 779 A over a distance of 9.85 km. The input voltage is specified as 39.5 kV. The voltage at the receiving end can be determined by applying Ohm's Law and the formula for voltage drop, which is essential for understanding power transmission efficiency.
  • Understanding of Ohm's Law
  • Knowledge of voltage drop calculations
  • Familiarity with power transmission line parameters
  • Basic electrical engineering concepts
  • Research "Ohm's Law applications in power systems"
  • Learn about "voltage drop calculations in transmission lines"
  • Explore "resistance and current relationships in electrical circuits"
  • Study "power transmission efficiency and loss reduction techniques"
Electrical engineers, students studying power systems, and professionals involved in designing or analyzing transmission line efficiency will benefit from this discussion.
jiten827
A pair of power transmission lines each have a 0.850 Ω resistance and carry 779 A over 9.85 km. If the rms input voltage is 39.5 kV, calculate the voltage at the other end.
where is your own workings, relevant equations/concepts?
identify what is what first and foremost if you are stuck
Do you have the entire problem stated correctly? I think it might be 0.850 ohms/m instead.
Plus you need to put forth some effort first.
  • · Replies 20 ·
12K
