Thread Closed
[SOLVED] Gauss' Law With an Infinite Cylinder of Charge
Share Thread Thread Tools
Oct27-07, 03:40 PM   #1
The test question was to find the potential difference between a point S above a cylinder of charger per length lambda, and a point on the surface of the cylinder having radius R and infinite length.
2. Relevant equations
Stupid me tried to grind through it during the test. But looking at the prof's solution:
http://www.phys.washington.edu/users...7exam1soln.pdf
Here's the test if you need to know the question how he worded it:
http://www.phys.washington.edu/users...21-07exam1.pdf
Problem #1.
I don't get how he got "E(s)*2pi*L*S
I get the 2pi and L come from integrating over phi and the length of the cylinder, but I can't figure out where that S came from.
Is it because you'd need a cosine(theta) for the direction that the cylinder is from S? Where cosine is S/distance? Then wouldn't he have to add in a bunch of other stuff? I'm just not seeing something here and I feel embarrassed.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Intel's Haswell to extend battery life, set for Taipei launch
>> Galaxies fed by funnels of fuel
>> The better to see you with: Scientists build record-setting metamaterial flat lens
Oct27-07, 04:27 PM   #2
[tex]\int E \cdot dA = EAcos(\Theta)[/tex]
Where [tex]\Theta[/tex] is the angle between the surface of the cylinder and the electric field.
Now, simplify this last expression. What is A? What is [tex]\Theta[/tex]?
Oct27-07, 04:46 PM   #3
Ohhhhhh I get it. A is 2pi*Length*radius, and he's just using S as the radius, since it shouldn't matter.
Gotcha, thanks a bunch.
Thread Closed
Thread Tools
Similar Threads for: [SOLVED] Gauss' Law With an Infinite Cylinder of Charge
Thread Forum Replies
why potential of an infinite line of charge not equals to zero at r = infinite General Physics 17
Gauss' Law and an infinite sheet Introductory Physics Homework 3
Gauss' Law: infinite planes Introductory Physics Homework 1
The work required for adding a charge to an infinite charge distribution Advanced Physics Homework 1
net charge VS dipole moment in E field by infinite line charge General Physics 5
