Equations of Motion (Deriving equations)
The discussion focuses on deriving the equation for velocity as a function of acceleration and time, specifically v = v0 + a(t2 - t1). The user seeks a step-by-step approach to arrive at this equation using the definitions of position, velocity, and acceleration. Key steps include recognizing that acceleration a(t) is the derivative of velocity with respect to time, leading to the integral relationship v(t) - v(0) = ∫a(t) dt. The challenge lies in expressing this integral in the desired functional form v = f(a, t).
  • Understanding of basic calculus, specifically integration and differentiation.
  • Familiarity with kinematic equations in physics.
  • Knowledge of the concepts of velocity, acceleration, and their relationships.
  • Ability to manipulate equations and understand initial conditions in motion.
  • Study the derivation of kinematic equations in physics, focusing on velocity and acceleration relationships.
  • Learn about integral calculus and its applications in physics, particularly in motion analysis.
  • Explore the concept of average velocity and its calculation from instantaneous values.
  • Investigate the assumptions made in physics regarding constant acceleration and their implications.
Students of physics, educators teaching kinematics, and anyone interested in understanding the mathematical foundations of motion equations.
arjun90
Hi, I am just wondering how you would approach this problem:
Using the definitions below, derive an equation for velocity as a function of acceleration and time (v=f(a,t)). Assume initial velocity is Vo. The answer to this problem is v=v0+a(t2-t1). My question is how would you arrive to this answer step-by-step. Below are the definitions:
x=current position in the x dimension
deltax= change in position
t=time now, t0 is the starting time.
deltat= a time interval, t2-t1.
v=deltax/deltat (use as a scaler for now).
deltav= a change in velocity.
a=deltav/deltat (Use as a scaler for now).
Subscripts: 0 is an initial value, other numbers are subsequent values in time order as needed.
v (average)= (v1+v2)/2, a simple average.
Any help will be appreciated. Thank you.
# I would first look at the definitaion of a
[tex]a(t) = \frac{dv(t)}{dt}[/tex]
# Integrate both sides
[tex]\int^{t}_{t_0} a(t) dt = v(t) - v(0)[/tex]
# This is the relation between v and a. but it is not in the form of you want, i.e. [tex]v=f(a,t)[/tex]. It is an integral equation.
# So, there should be an assumption about a, which changes integral the relation between a and v to a function. I think if you think, you can find it by yourself.
