How Do You Determine the Y-Coordinate of a Circle's Center?
  • Thread starter Thread starter unique_pavadrin
    Circle Point
The discussion revolves around determining the center point of a circle given specific coordinates of points on its circumference. The problem involves understanding the geometric properties of circles and the relationships between points and the center.
  • Participants explore methods to find the y-coordinate of the circle's center by using the symmetry of the circle and the distances between given points. There are attempts to apply geometric principles such as the perpendicular bisector and midpoint calculations. Questions arise regarding the effectiveness of simultaneous equations in solving for the unknown constant.
Some participants have provided guidance on using distances and geometric properties to find the center. There is an ongoing exploration of different methods, and while some calculations have been presented, there is no explicit consensus on the approach to take.
The original poster has shared a diagram and specific coordinates, but the discussion hints at potential assumptions about the circle's properties that may need clarification. The problem is framed within a homework context, which may impose certain constraints on the methods used.
unique_pavadrin
URGENT: Centre Point of a circle
Find the center point of the circle shown in the diagram below and the radius of the circle.
http://img142.imageshack.us/img142/9469/45409301jg6.png
The red dots have the following coordinates; (-17,0); (0,17); (31,0)
[tex]\left( {x + a} \right)^2 + \left( {y + b} \right)^2 = r^2[/tex]
I can find the x-coordinate of the center of the circle finding the center point between (-17,0) and (31,0), and as the circle is symmetrical, this will be the x-coordinate of the center point. The value is 7, therefore the center of the circle is located (7,c) where c is some constant.
how do i find the value of the constant?
Many thanks,
unique_pavadrin
The distance between (7,c) and (0,17) equals the distance between (7,c) and (31,0).
use this to find c, and and then r also...
sorry i don't see how that helps
would simultaneous solving of some sort help?
The perpendicular bisector of any chord in a circle goes through the center. You used that when you calculated the midpoint of the horizontal line between (-17,0) and (31,0): its midpoint is (7,0) and its perpendicular bisector is x= 7. Now choose another two of those points, say (-17, 0) and (0, 17). The midpoint of that segment is (-17/2, 17/2). The slope of that segment is (17-0)/(0-(-17))= 1. The slope of a line perpendicular to that is -1. The equation of the perpendicular bisector of that segment is y= -x+ 17. The center is at the intersection of y= -(x+ 17/2)+ 17/2 and x= 7. That should be easy to solve.
So the centre is (7, c).
Length of segment joining (-17, 0) and center
r^2 = 24^2 + c^2
r^2 = 576 + c^2 _____(Eq 1)
Length of segment joining (0, 17) and center
r^2 = 7^2 + (c-17)^2
r^2 = 49 + c^2 + 289 -34c _______(Eq 2)
Comparing Eqs. 1 and 2:
576 + c^2 = 49 + c^2 + 289 -34c
c = -7
Therefore the centre of the circle is (7, -7).
Finding radius now is pretty trivial.
cheers for that, makes sense now, the radius is [tex]\sqrt {149}[/tex]? correct...
