Two problems involving rotational movement
The discussion focuses on two problems involving rotational movement and the application of torque and energy conservation principles. In the first problem, a disc with a mass of 50 kg and a radius of 20 cm stops after 50 seconds, with a calculated torque of -1.21924 Nm. The second problem involves a 17 kg cylinder with a rope and a 5 kg bob, where the potential energy is calculated as 192.2 J. The participants clarify the correct use of the moment of inertia and the relationship between linear and angular velocities.
  • Understanding of rotational dynamics and torque
  • Familiarity with moment of inertia calculations
  • Knowledge of energy conservation principles in physics
  • Ability to convert between linear and angular velocity
  • Study the derivation of torque in rotational systems
  • Learn about the conservation of mechanical energy in rotating bodies
  • Explore the relationship between linear and angular momentum
  • Investigate the effects of friction on rotational motion
Physics students, educators, and anyone interested in understanding the principles of rotational motion and energy conservation in mechanical systems.
dzogi
1. First Problem
A disc with mass of 50kg and radius of 20cm is rotating with a frequency of 480rpm, and after 50 seconds, as a result of the force of friction, it stops. What's the moment (momentum of force, torque) if during the rotation the disc made 200 rotations?
[tex]M=I\epsilon[/tex]
[tex]R=0,2m; m=50kg; f=480min^{-1}=8Hz; t=50s; N=200;[/tex]
[tex]w_0=\frac{2\pi}{1/8}=16\pi rad/s[/tex]
[tex]w = 0rad/s[/tex]
[tex]\epsilon=\frac{w-w_o}{t}=\frac{-16\pi}{50}rad/s[/tex]
[tex]I=0.5mR^2=1[/tex]
[tex]M=I\epsilon=-1.21924Nm[/tex]
Is this correct? I can't see where to number of total rotations (angular distance) fits in, or maybe it's a distractor?
2. Second problem
А rope is wrapped around a horizontal cylinder with [tex]M=17kg; R=0,1m[/tex]. A bob with [tex]m=5kg[/tex] is attached at the end of the rope, at height of [tex]h=4m[/tex] above ground. The momentum of inertia of the cylinder is calculated with [tex]I=\frac{MR^2}{2}[/tex].
a) what's the speed of the bob when it hits ground?
b) calculate the total energy of the system.
I've solved b) pretty easily,
[tex]E=mgh=192,2J[/tex] which conforms to the solution in the book (so, the potential energy of the cylinder is ignored).
I've tried solving a) this way
[tex]mgh=\frac{mv^2}{2}+\frac{I\omega^2}{2}[/tex]
If the liner velocity of the cylinder is equal to the speed of the bob at any given time, then we can substitute [tex]\omega=\frac{v}{R}[/tex]
[tex]\vdots[/tex]
Is this approach correct? I don't get the same solution with the one given in the book.
[tex]mgh=\frac{mv^2}{2}+\frac{M\omega^2}{2}[/tex]
[tex]\vdots[/tex]
Problem 1 seems fine.
Kinetic energy of the cylinder should be [tex]\frac{I\omega^2}{2}[/tex] and not [tex]\frac{M\omega^2}{2}[/tex], ain't it?
Yes, it was a mistype :)
  • · Replies 78 ·
11K
  • · Replies 19 ·
