Momentum in a Many-Particle System
  • Thread starter Thread starter Jacobpm64
    Momentum System
The discussion focuses on calculating the average force exerted by bullets from a Maxim machine gun and the rate at which they deliver energy to a target. Given that the gun fires 450 bullets per minute, each with a mass of 14 g and a velocity of 630 m/s, the average force calculated is 3969 N. Additionally, the average rate of energy delivery to the target is determined to be 1250235 J/min. These calculations utilize principles of momentum and kinetic energy.
  • Understanding of momentum and its relation to force (dp/dt = F)
  • Knowledge of kinetic energy formula (K = 1/2 mv^2)
  • Basic calculus for differentiation
  • Familiarity with units of measurement (N, J, kg, m/s)
  • Review the principles of momentum in physics, particularly in non-isolated systems.
  • Study the derivation and application of the kinetic energy formula in various contexts.
  • Explore advanced topics in dynamics, including impulse and conservation of momentum.
  • Learn about energy transfer mechanisms in impact scenarios.
Physics students, educators, and professionals in engineering or ballistics who are interested in the dynamics of projectile motion and energy transfer in impact situations.
Jacobpm64
A Maxim machine gun fires 450 bullets per minute. Each bullet has a mass of 14 g and a velocity of 630 m/s.
(a) What is the average force that the impact of these bullets exerts on a target? Assume the bullets penetrate the target and remain embedded in it.
(b) What is the average rate at which the bullet deliver their energy to the target?
We probably need the fact that [tex]\frac{dp}{dt} = F_{ext}[/tex]. (i'm not sure if the system is isolated).
(a)
Well, momentum = mass * velocity
So, I can find the momentum of one bullet easily:
[tex]p = mv[/tex]
[tex]p = (0.014 kg) * (630 \frac{m}{s})[/tex]
[tex]p = 8.82 kg * \frac{m}{s}[/tex] <--- momentum of a single bullet.
Now, I can set up the equation:
[tex]p_{total} = 450 (0.014) (630) t[/tex] <--- because there's 450 bullets.. and I put the t in there because you don't know how many minutes.
Now, you want force, and since [tex]\frac{dp}{dt} = F_{ext}[/tex], you can differentiate the above expression:
[tex]\frac{dp}{dt} = 450 (0.014) (630)[/tex]
[tex]F_{ext} = 3969 N[/tex]
(b)
Well, the kinetic energy of the bullets is [tex]K = 450 * \frac{1}{2} * m * v^2 * t[/tex]
With numbers, [tex]K = 450 * \frac{1}{2} * (0.014) * (630)^2 * t[/tex]
Now to get the rate at which the bullets deliver their energy (rate of change of energy), we differentiate this expression:
[tex]\frac{dK}{dt} = 450 * \frac{1}{2} * 0.014 * (630)^2[/tex]
[tex]\frac{dK}{dt} = 1250235 J / min[/tex]
Is this correct?
Thanks in advance.
Jacobpm64 said:
Is this correct?
I haven't checked the calculations, but reasoning part sounds good to me!
  • · Replies 27 ·
  • · Replies 29 ·
  • · Replies 31 ·
