Analyzing Block & Spring Compression: F = -kx & W = -0.5kx^2
The discussion focuses on the mechanics of a block with a mass of 0.528 kg sliding at a velocity of 3.85 m/s, striking a spring with a spring constant of k=26.7 N/m. The kinetic energy of the block is calculated to be 3.913 J upon impact with the spring. The conversation explores how to determine the compression of the spring when friction is absent versus when a coefficient of kinetic friction (uk = 0.411) is present, emphasizing the transformation of kinetic energy into elastic potential energy and the role of friction in energy dissipation.
  • Understanding of Newton's laws of motion
  • Familiarity with the concepts of kinetic and potential energy
  • Knowledge of spring mechanics and Hooke's Law
  • Basic principles of friction and energy dissipation
  • Calculate spring compression using the formula W = -0.5kx^2
  • Explore the effects of varying spring constants on compression
  • Investigate the impact of different coefficients of friction on energy dissipation
  • Learn about energy conservation principles in mechanical systems
Physics students, mechanical engineers, and anyone interested in understanding the dynamics of spring systems and energy transformations in frictional and non-frictional environments.
Pavel1989
A block of mass 0.528 kg slides with uniform velocity of 3.85 m/s on a horizontal frictionless surface. At some point, it strikes a horizontal spring in equilibrium. If the spring constant is k=26.7 N/m, by how much will the spring be compressed by the time the block comes to rest? What is the amount of compression if the surface is rough under the spring, with a coefficient of kinetic friction uk = 0.411?
F = -kx W = -0.5kx^2 KE = 0.5mv^2
I found that it has 3.913 J of energy once it hits the srping, but how do i use that and incorporate it into the work done by the spring?
The spring mechanical energy = work done by/on the spring.
Without dissipating force (e.g. friction), the kinetic energy of the mass is transformed into the mechanical (elastic) energy stored in the spring.
With friction present, some of the kinetic energy is dissipated by friction.
Think of work = [itex]\int_0^x F(s) ds[/itex], and there will be + or - sign depending whether work is done on or by the system (e.g. spring).
thanks much i think I've got it
