Momentum in two directions(q35)
  • Thread starter Thread starter jack1234
    Momentum
The discussion revolves around a momentum problem involving two particles moving at angles to the x-axis. Participants are analyzing the momentum conservation equations in both x and y directions to understand the relationships between the velocities of the particles.
  • Participants present their equations for momentum conservation in both directions and question the validity of their setups. There is discussion about the direction of the y-components of the velocities and how that affects the overall momentum.
Some participants have provided guidance on correcting the y-component equation and have raised questions about the implications of the direction of motion for the particles. There is an exploration of the assumptions regarding the direction of the y-components and the conservation of momentum.
Participants are considering the implications of the problem setup, particularly the angles at which the particles are moving and how that affects the momentum calculations. There is an emphasis on the need to clarify the directions of the components based on the problem statement.
jack1234
Hi, for this question
http://tinyurl.com/yvadld
This is what I have done:
in x direction
5*60=5*v1*cos30 + 2*v2*cos30 --(1)
In y direction
0=5*v1sin30 + 2*v2sin30 --(2)
From (2), v1=-(2/5)*v2 subs into (1)
And what I get is 300=-2*v2*cos30 + 2*v2*cos30
What is the problem?
in x direction
In y direction
you should use:
0=5*v1sin30 - 2*v2sin30 --(2)
the two particles have opposite directions for y-components.
Got it, answer is b:)
But does it mentioned in the question...or it just common sense?
What I mean is "the two particles have opposite directions for y-components."
You are told that each particle has a velocity that is 30 degrees from the original direction (along the x-axis). Is it possible (considering conservation of momentum) that the two particles both move to the same side of the x-axis?
Hint: What's the y-component of total momentum?
I see...so it is base on observation:)
It is based on conservation of momentum.
  • · Replies 16 ·
  • · Replies 19 ·
  • · Replies 16 ·
  • · Replies 23 ·
