"400N Child in Swing: Calc Potential Energy
  • Thread starter Thread starter ~christina~
    Swing
The problem involves calculating the gravitational potential energy of a 400N child in a swing with ropes that are 2.0m long. The discussion focuses on different positions of the swing, including when the ropes are horizontal, at a 30-degree angle with the vertical, and at the bottom of the swing's arc.
  • Participants discuss the interpretation of the gravitational potential energy and whether the height should be measured from the ground or the child's lowest position. There are inquiries about the assumptions made regarding the child's height above the ground and how to calculate the height at different angles of the swing.
Some participants have provided insights into the interpretation of the problem, suggesting that the height should be measured relative to the child's lowest position. Others are exploring how to calculate the height at a 30-degree angle and questioning the implications of the child being at the bottom of the arc.
There is a mention of a diagram that participants are using to visualize the problem, and some confusion remains regarding the use of angles and the concept of "datum" in the context of measuring height.
~christina~
[SOLVED] 400N child on swing
A 400N child is in a swing attatched to ropes 2.0m long
Find the gravitational potential energy of the child Earth system relative to the child's lowest position when
a) the ropes are horizontal
b) rope makes angle 30 deg with vertical
c) child is at bottom of circular arc
[tex]U_g= mgy[/tex]
First of all for this question in general would I be finding the Wnet of the system and thus the change in potential energy of the system? Is that what they want when they say "find the gravitational potential energy of the child Earth system?
When they say a "400N child"
does that mean I can consider that the force of the mass and the gravity already multiplied and thus I can just use that in place of mg
a) I think that the distance y for a would be 2m b/c the ropes are horizontal and thus since the length of the ropes are 2m then it would be logical that the distance traveled would be 2m.
Would I assume that the child is a distance 0.5m above the ground?
I think I would.. assuming they want the net force
Wnet= [tex]\Delta U_g[/tex]
Ui= mgyi = 400N (0.5m)= 200J ====> does that seem sort of large??
I would like to see if my thinking is correct before I go further..
Could someone Please help me ?
Thanks :smile:
Where did the 0.5 come from?
well the book assumed heights on another question so...
but seriously the child wouldn't be sitting on the floor right?
Ah. Well, you don't need to assume anything for this. It asks for everything relative to the child, right? This means it doesn't matter how high off the ground the child is, only how high he/she gets from his/her lowest point.
You know how high that is, so just use the Energy = Force * Height equation.
but how would I find the height for part b?
b) gives the angle that it has with the vertical but I don't know how I'd find the height traveled by it.
c) child=> at bottom of arc so I think that means it doesn't move and thus the height would be 0?
wouldn't that give potential E= 0? I know that that can't be though...
Help?
My interpretation is that the "child's lowest position" is when the "child is at bottom of circular arc" so I'd take that as datum and measure all other heights above it.
This leads to the GPE in part c being trivially easy.
For part b the rope is straight, at 30 degress to vertical and the child at the end of it. How much higher is the child compared to when the rope is vertical?
first..what is "datum"??
c) isn't it...0m ? since the child doesn't move...
this gets me confused since I know that the equation is
Ug= mgy
but if y= 0...that would make the rest of the equation = 0 too...
b) I seriously don't know how I'll get the difference in height of the child compared with before with a 0 deg angle...
Thanks.
Datum is Latin for "given" (and you thought this was the Physics forum!) and is used here in the sense it is used when mapmaking and surveying to indicate level zero. See http://en.wikipedia.org/wiki/Datum for more than you ever wanted to know.
c)
"but if y= 0...that would make the rest of the equation = 0 too...". Exactly. That's what I meant by trivially easy; it doesn't get much easier!
b)
It's so easy I don't know how to explain. I guess you are somehow making it harder than it really is. Have to go now. Will need a diagram if you don't figure it out before tomorrow.
http://img148.imageshack.us/img148/488/93788848yr1.th.jpg
I drew a picture..seriosly you say it's easy but do I have to use the angle or anything??
I really really really don't know how to get it...and it' not like I know what to look up to find it either so I'm just staring at the problem...
Thanks for the diagram. Yes you have to use the angle.
Draw a horizontal from the mid point of the grey seat. Now you have a right angled triangle. The hypotenuse is the full length of the rope, let's call it L. The vertical side is the full length of the rope minus h, that's (L - h)
The length of the vertical side is Lcosθ
where
L is the length of the rope
θ is the angle of the rope with the vertical
Now I really am going!
where
Hm...Is this what you mean??
I wasn't sure what you mean by vertical...b/c you state vertical twice ..once as L-h then 2nd as Lcos theta...
http://img100.imageshack.us/img100/1567/88164147ft0.th.jpg
What I got from your explanation was that...
L-h ==> the line that was drawn from the 2 different points of the swing...
Lcos theta = L? do I plug that into L in the L-h ??
this is what he meant by a right triangle.
Use [tex]cos(\theta) = adjacent/hypotenuse[/tex] to find x.
Then, to find how high the child has risen, subtract x from 2m.
Thank You both I get how to do the problem now :smile:
