How Close to Speaker B Causes Destructive Interference at 172 Hz?
The discussion revolves around the concept of destructive interference of sound waves emitted by two loudspeakers operating at a frequency of 172 Hz. The original poster is trying to determine the closest distance to speaker B while standing 8.00 m from speaker A, given the speed of sound in air as 344 m/s.
  • The original poster attempts to visualize the problem by calculating the wavelength and applying the condition for destructive interference. They express confusion about determining the correct value of n for the shortest distance to speaker B.
  • Some participants question the necessity of knowing the distance between the two speakers and suggest that it is crucial for solving the problem.
  • Others raise concerns about the validity of using n=1 and whether the approach is correct, indicating a lack of clarity in the reasoning process.
The discussion is ongoing, with participants exploring different interpretations of the problem. Some guidance has been offered regarding the use of n=1 for the shortest distance, but there is no explicit consensus on the correct approach or solution. The original poster expresses frustration and seeks further assistance.
There is uncertainty regarding the distance between the two speakers, which may affect the calculations. The original poster has noted that all necessary information has been provided, yet confusion persists about the application of the interference condition.
jaded18
[SOLVED] Interference of Sound Waves
Two loudspeakers, A and B, are driven by the same amplifier and emit sinusoidal waves in phase. The frequency of the waves emitted by each speaker is 172 Hz. You are 8.00 m from speaker A. Take the speed of sound in air to be 344 m/s.
What is the closest you can be to speaker B and be at a point of destructive interference?
__________I am having the hardest time trying to visualize the problem. I know that destructive interference occurs when the difference in path lengths traveled by sound waves is a half integer number of wavelengths. So I need to know the wavelength of the sound which is just 2m.
I also know that in general if d_a and d_b are paths traveled by two waves of equal frequency that are originally emitted in phase, the condition for destructive interference is d_a-d_b=n(wavelength)/2 where wavelength is what I calculated it to be (2m) and n=any nonzero odd integer. I think I need to know what the value of n is that corresponds to the shortest distance d_b to solve my prob. (is d_a=8m? then what is d_b?)
I'm going around in circles and getting nowhere. Please help!
Take n=1 for shortest distance from speaker B.
Usually, it is important to know the distance between the two speakers. Is this not given?
Then you can move B wherever you like. If you are 8 m from A, and wavelength is 2 m, the sound form A has traveled 4 full integer multiples of the wavelength. You must place B at a location such that the sound will arrive 1/2 wavelength out of phase. One full wavelength? or less? how much less?
apparently n=1 is not the right answer.
all info has been given.
gahh. i need help. Yes, sound from A has traveled 4X the wavelength of sound emitted by the loud speakers. Sound from B must be moved so that the sound arrives 1/2 wavelength out of phase (d_a-d_b=n(wavelength)/2) so are you telling me the same thing that Vijay told me, that n=1?
am i approaching this the wrong way? ..Nobody??
The correct answer is 1.00m.
Hint: The closest you can be to B. (lamda/2)
  • · Replies 19 ·
