How Do You Calculate the Force Affecting Pressure in a Viscosity Experiment?
The discussion revolves around calculating the force affecting pressure in a viscosity experiment involving a tube. The original poster is attempting to measure viscosity for different liquids and is struggling to determine the pressure difference, denoted as "p". They are exploring the relationship between pressure, force, and area in the context of their experiment.
  • Participants are discussing the definition of pressure as force divided by area and questioning what constitutes the force in this specific experimental setup. There are attempts to clarify the relationship between pressure and force, as well as the role of gravity in this context.
The discussion is ongoing, with participants raising questions about the definitions and relationships involved in the problem. Some guidance has been offered regarding the definition of pressure, but there is no explicit consensus on how to determine the force needed for the calculations.
Participants are navigating potential misunderstandings related to fluid mechanics and the specific parameters of the experiment, such as the cross-sectional areas involved and the role of gravity in determining force.
jamesyboy1990
1. Homework Statement
where:
l = the length of the tube in cm
r = the radius of the tube in cm
p = the difference in pressure of the two ends of the tube in dynes per cm2
c = the coefficient of Viscosity in poises (dyne-seconds per cm2)
v = volume in cm3 per second
pi = 3.14159... (i couldn't get the symbol to appear)
I am doing an experiment in which i measure viscosity for different liquids. However, I'm having problems in obtaining value "p". I know that pressure is force times area. In this case, area should be the cross sectional area for the tube at one end, and the cross sectional area of the valve opening at the other end (if I'm not mistaken). However, what will be the force?
2. Homework Equations
where:
3. The Attempt at a Solution
Isn't pressure defined as force divided by area?
oooo, typo. your right, i meant force PER UNIT area. but still, any ideas on my problem?
[tex]\frac{r^{4}(pi)p}{8cl}[/tex]
No, I was horrible at fluid mechanics. I was just making sure you didn't write it down wrong on your paper and then get confused. Aside from that, I'm useless.
Would the force be gravity?
  • · Replies 18 ·
  • · Replies 74 ·
16K
