Removing Pb2+ from Water: EPA Standards & NaCl Solution
  • Thread starter Thread starter sveioen
    Water
The discussion revolves around the removal of Pb2+ ions from water, specifically in relation to EPA standards for drinking water. Participants explore the use of NaCl to precipitate lead as PbCl2 and the implications of this method, including potential environmental impacts and safety concerns.
  • Homework-related
  • One participant states that the EPA recommends a maximum concentration of Pb2+ at 1.00 x 10-7 M in drinking water and questions the concentration of NaCl needed to achieve this.
  • Another participant explains the relationship defined by the solubility product constant (Ksp) for PbCl2 and suggests that a significant amount of salt would be required, raising concerns about the ecological impact of high salinity in water sources.
  • A participant emphasizes the need to avoid using hot water, as PbCl2 is more soluble at higher temperatures, which could pose health risks.
  • There is a mention of other anions that could be problematic for drinking water, such as NO3-, when precipitating Pb with Cl-.
  • Some participants express skepticism about the nature of the inquiry, suggesting it resembles a basic chemistry homework question rather than a practical issue faced by individuals with contaminated water.
Participants do not reach a consensus on the appropriateness of using NaCl for removing Pb2+ from water, with multiple concerns raised about the environmental and health implications of this approach.
Participants highlight the need for careful consideration of the ecological consequences of creating saline environments and the potential health risks associated with the solubility of PbCl2 in hot water.
sveioen
[SOLVED] Removing Pb from water
The Environmental Protection Agency recommends that Pb2+ have a concentration not exceeding 1.00 x 10-7 M in drinking water. What concentration of NaCl could be used to remove the lead from the water to bring it to a safe level? Ksp for PbCl2 is 1.6 x 10-5. What would the drawbacks of doing this be?
Could anyone get me going with this?
Chemistry news on Phys.org
Ksp=[Pb2+][Cl-]^2 by definition.
You are given the KSP and Pb2+ values, simply find the concentration of Cl-. You will notice that you will need a LOT of salt to do this, and creating highly saline environments in water sources kills a lot of plants and wildlife.
Wow, so it is that easy. Thank you very much gravenewworld!:smile:
Ok, however don't do it with hot water, or you'll kill people (PbCl2 is quite soluble in hot water).
Furthermore, precipitating Pb with Cl- obviously take in solution the anion and this one can be not appropriate itself for a drinking water: NO3- for example.
This sounds more like Chemistry 101 homework than somebody with bad well water. But, you never know.
Agree :approve:
14K
