How Does Adding Sodium Citrate Affect the pH of a Citric Acid Solution?
  • Thread starter Thread starter sam.
    Chemistry Ion
The addition of sodium citrate to a 0.270 M citric acid solution significantly alters the pH. Initially, the pH of the citric acid solution is calculated to be 2.67 using an ICE table and the dissociation constant (pKa = 4.77). After adding sodium citrate to achieve a final concentration of 0.145 M for the citrate ion, the final pH is determined to be 4.50. This demonstrates the buffering effect of the citrate ion in the solution.
  • Understanding of acid-base equilibrium and pH calculations
  • Familiarity with ICE tables for equilibrium concentrations
  • Knowledge of dissociation constants (Ka and pKa)
  • Basic chemistry concepts related to weak acids and their conjugate bases
  • Study the Henderson-Hasselbalch equation for buffer solutions
  • Learn about the effects of different concentrations of weak acids and their salts on pH
  • Explore the concept of buffer capacity and its practical applications
  • Investigate the role of sodium citrate in various biochemical applications
Chemistry students, laboratory technicians, and professionals involved in biochemical research or formulation who need to understand pH adjustments in solutions.
sam.
What is the pH change of a 0.270 M solution of citric acid (pKa = 4.77) if enough sodium citrate is added to make the final concentration of the common citrate ion 0.145 M?
Okay so first I did an ice-table using the equation:
citric acid + water <--> hydronium + citric ion
Using an inital concentration of 0.270 for citric acid and then just solving for x using the Ka value and I got pH = 2.67 (which is the initial pH).
Now I'm having a problem with how to find the final pH. I think you're supposed to set up another ice table but I'm not too sure what values are supposed to be my initial concentrations. Any help would be greatly appreciated!
Chemistry news on Phys.org
HA + H2O <--> H3O+ + A-
[HA] = 0.270 - x
[H3O+] = x
[A-] = 0.145
[H3O+]*[A-]/[HA] = Ka = 10^(-4.77)
--> x*0.145/(0.270 - x) = 10^(-4.77)
--> x = 3.16*10^(-5) --> pH = 4.50
10K
