Simple roots of a quadratic question
  • Thread starter Thread starter rock.freak667
    Quadratic Roots
The discussion revolves around a quadratic equation of the form x^2 + px + q = 0, focusing on the roots α and β. Participants are tasked with forming a new equation based on the reciprocals of these roots and exploring properties of α as a root of another equation, specifically x^2 = 2x - 3.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants discuss how to derive an equation from the roots of the original quadratic and express confusion regarding the implications of the roots being imaginary. There are attempts to relate the roots to the given equations and to verify identities involving α.
Some participants have provided insights into the relationships between the roots and the equations, while others are exploring the implications of using imaginary roots. There is an ongoing examination of the mathematical expressions and their validity without reaching a consensus.
Participants note that the discriminant of the quadratic equation is negative, indicating that the roots are imaginary. There is also mention of the need to use the original equation to derive results rather than substituting values directly.
rock.freak667
Given that the roots of [itex]x^2+px+q=0[/itex] are [itex]\alpha and \beta[/itex], form an equation whose roots are [itex]\frac{1}{\alpha} and \frac{1}{\beta}[/itex]
b) Given that [itex]\alpha[/itex] is a root of the equation [itex]x^2=2x-3[/itex] show that
i)[itex]\alpha^3=\alpha-6[/itex]
ii)[itex]\alpha^2-2\alpha^3=9[/itex]
[tex]\sum\alpha=\frac{-b}{a}[/tex]
[tex]\sum\alpha\beta=\frac{c}{a}[/tex]
well for part a) I can do that simply
but it is part b) that confuses me, as I can simply factorize what the eq'n and get 1 and -3 as the roots..but I don't see how i can use those numbers to prove what they want to show...
Are you quite sure the roots are 1 and -3? What is the discriminant?
ah wait...wrong sign i used...must redo
Well the roots are imaginary, but if i take [itex]\alpha[/itex] to be one of them and cube it I wouldn't get what i want
What exactly were the roots you found? I just tried out (b-i) and got that to work. I'm trying (b-ii) now...
1+- 2sqrt(2)i
rock.freak667 said:
1+- 2sqrt(2)i
I find the discriminant to be -8 , so the imaginary part would be just sqrt(2).
ah...forgot to divide the imag. part by 2...but if i take [itex]\alpha[/itex] as either of the 2 roots it will work out?
You'll find that changing the sign of the imaginary part only flips the signs of certain terms in the expressions you are evaluating in a manner that still allows them to cancel out. Try it on (b-i)...
Of course, actually solving the equation and using those values as [itex]\alpha[/itex] defeats the point of the problem: use the equation itself!
If [itex]\alpha[/itex] satisfies [itex]x^2= 2x- 3[/itex] then obviously [itex]\alpha^2= 2\alpha - 3[/itex] so [itex]\alpha^3= 2\alpha^2- 3\alpha[/itex]. But, again, [itex]\alpha^2= 2\alpha - 3[/itex] so [itex]\alpha^3= 2(2\alpha- 3)- 3\alpha= \alpha - 6[/itex]
  • · Replies 20 ·
  • · Replies 17 ·
  • · Replies 22 ·
