Is My Monitor Causing These Minor Issues with My Computer?
  • Thread starter Thread starter proton
    Monitor
The discussion revolves around potential issues with a computer monitor and its interaction with the video card, as experienced by a user. The user describes various symptoms including screen freezes, display errors, and problems with dark backgrounds while browsing. The scope includes troubleshooting and technical explanations related to hardware performance and software drivers.
  • The user reports intermittent screen freezes and display errors when browsing, which temporarily resolve upon refreshing the page or restarting the monitor.
  • Some participants suggest that the video card may be at fault, with one noting a similar experience with an older video card model.
  • Another participant proposes that the issue may stem from driver problems, recommending that the user check and update video card drivers.
  • One participant argues that the symptoms described do not align with typical monitor issues, suggesting that software bugs or adware could be responsible for the display problems.
  • Another response emphasizes the need to reinstall monitor drivers or consider replacing the video card if issues persist.
Participants express differing views on whether the monitor or the video card is the source of the problems. There is no consensus on the root cause, with some attributing the issues to hardware while others suggest software-related factors.
Participants mention the importance of keeping drivers updated and consider the possibility of adware affecting performance. There are unresolved questions regarding the specific nature of the display issues and the effectiveness of proposed solutions.
proton
I've noticed 3 things: that about 3 times/day (I use the computer for about 4 hrs/day, rough estimate), as I'm surfin the net, the screen just freezes for a second and then the page I'm viewing gets messed up. Like for example, when I'm reading a paragraph on a website, it gets erased or appears twice. But this isn't much of an issue because if I just revisit the page, it looks normal again.
Another issue, which happens rarely, is that all of a sudden the screen gets all messed up - I can't see the webpages, windows, mouse arrow, nothing. This is also easily taken care of. I just turn off and then back on the monitor.
I've also noticed that when I try to visit webpages that have a dark or black background, the monitor can't show anything, unless I hit ctrl+alt+del, where I just have to restore down the window, and then I can see everything.
These are all minor issues, but do I have to start worrying that my monitor or video card or something else has problems. BTW, I have a 17" samsung syncmaster 171v monitor
Computer science news on Phys.org
This is just a shot in the dark, but you tried changing resolutions? At first it sounded like your video card is at fault because I had an old Matrox Millenium that sometimes acted like yours. Being able to temporarily fix it by switching off the monitor makes me think that it could be a driver issue. Worse case scenario... the monitor is dying.
The first thing i would do is make sure the video card drivers are up to date. Do you have another LCD monitor to test?
well the problem was a little worse a few weeks ago, when I had a larger resolution. my video card drivers are up to date. So my monitor must be the problem
With one exception, what you are describing doesn't sound like a monitor problem. A monitor doesn't store any information, so it can't do things like what you describe. The problem that occurs when "the screen gets all messed up" (not very descriptive...) must be.
Windows (and video card drivers) often have bugs where they draw things incorrectly - especially in IE. But they can also be messed up by programs. Try running AdAware to make sure you don't have any adware messing up your operations. Also make sure Windows is up to date - go to www.windowsupdate.com .
Windows drivers are unlikely the source of your problem. I would reinstall the monitor drivers that came with your monitor or download a clean copy from the Samsung website. If that doesn't help, it might pay to replace the vid card.
  • · Replies 30 ·
