Laptop performance and noise problems
The discussion revolves around a laptop experiencing a loud roaring noise accompanied by a significant slowdown in performance. Participants explore potential causes, focusing on the cooling fans and hard drive, and consider the relationship between these components and the observed issues.
  • One participant suggests that the noise and performance issues may be due to problems with the cooling fans or the hard drive, questioning if fan issues could lead to performance slowdowns.
  • Another participant shares personal experience, indicating that fan problems have caused similar symptoms in higher performance laptops, recommending running fan diagnostics and cleaning the fans.
  • A different participant raises the possibility that the noise could be a high-pitched whine from the hard drive, linking the performance slowdown to potential fan obstructions or failing bearings.
  • One participant advises sending the laptop to a service center for cleaning, while also noting they managed to resolve a similar issue themselves.
  • Another participant confirms that overheating can lead to reduced performance, as modern processors adjust their clock speeds in response to high temperatures.
Participants express varying opinions on the root cause of the issues, with some focusing on the fans and others considering the hard drive. There is no consensus on the exact cause or the best course of action, indicating ongoing uncertainty and multiple competing views.
Participants mention various diagnostic approaches and personal experiences, but there are unresolved assumptions regarding the specific nature of the noise and the exact relationship between the components involved.
Individuals experiencing similar laptop performance and noise issues, as well as those interested in laptop maintenance and troubleshooting.
dmehling
Just a couple of weeks ago, my laptop started making a very loud roaring noise and experienced a severe slowdown in performance (programs and windows open very slowly) at the same time. It takes a couple minutes after booting up for the noise to begin, but once it starts it is continuous. At this point, I am thinking it is either one of the cooling fans or the hard drive. Is it possible that problems with the fans could cause a performance slowdown? But if it's the hard drive, is it possible for it to produce a constant roaring fanlike noise?
Computer science news on Phys.org
I'd first go after the fans. Or at least that's a problem have encountered a couple of times in the past with "higher performance" laptops with similar symptoms (have had to replace fans a number of times). If it overheats can result in a slowdown, and would probably run fan diagnostics to see if they find anything (can you boot it to a diagnostic mode, did it come with a boot CD with diagnostics or does the manufacturer offer a diagnostic image to burn / or a related utility in other form at their website...).
Sure running compressed air through the fans may be a good idea as well (I had one laptop where the fans were somehow "tilted" to begin with and after a while it started to "roar" , and couple of other cases where they've developed similar issues with time. Actually only one which got stuck without making a huge noise in the process). If the voice is "really loud" (+the slowdown) would say it's the fan(s) over HDD. The diagnostics run the fan at differing speeds and if the full speed (for example) is seriously lacking it's a good indication something is wrong.
Is it a higher-pitched whine? Because of the high rotational speeds (4,500-5,400rpm) the bearings usually make noise in the upper register when they're going out, but that doesn't necessarily rule out the hard drive. The fact that there is a performance slowdown makes me think it could be a clogged fan or one with shot bearings.
Remove the underside panel that houses the cpu and fan. See if you notice any obstructions.
the problem mostly deals with the fan, you should send it to the store or service center to open it and clean it.
I have the same problem too, but i did it myself.
Yes, overheating can lead to poor performance. Modern processors monitor their own temperatures and reduce their clock speeds when they begin overheating.
- Warren
  • · Replies 29 ·
  • · Replies 30 ·
  • · Replies 123 ·
21K
  • Poll Poll
12K
