Thread Closed
Non-Inverting Operational Amplifier.
Share Thread Thread Tools
Nov27-07, 05:26 PM   #1
Good evening.
Right. My question is one of a simple nature, I think.
Anyways, consider the following non-inverting Op-Amp design:
http://www.freewebs.com/mushg/FWThumbnails/OpAmp.bmp
Now, the basic formula for any non-inverting opamp is of course [latex]\frac{V_{O}}{V_{S}} = 1 + \frac{R_{2}}{R_{1}}[/latex]
Meaning that [latex]V_{O} = V_{S} + \frac{V_{S}R_{2}}{R_{1}}[/latex]
I'm trying to find [latex]V_{O}[/latex]
My question, how do I take into account the[latex]R_{S}[/latex] In this situation? Does it have any bearing at all, if so, what?
Thanks
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> King Richard III found in 'untidy lozenge-shaped grave'
>> Google Drive sports new view and scan enhancements
>> Researcher admits mistakes in stem cell study
Nov27-07, 06:06 PM   #2
Recognitions:
Gold Membership Gold Member
Well, since the inputs are very high impedance, there's no current into them. Hence the R_s has no effect on the gain.
Dec2-07, 06:30 PM   #3
Hi,
Rs= 1.2k has nbo bearing at all. You cannot simply memorize the formulae for inverting and noninverting amps and solve every opamp question. You need to do it fron first principles. Heres how.
1. V+= V- (thats a given)
2. I= = I-= 0A (very little or no current in the order of pico amps enters intoi the terminals of the opamp ...it can be neglected)
3. You have an expression for V- being V-= Vout(5k)/(15K) by voltage divider and you have V+= 2A (no V drop across Rs as I+= 0A)
<< final solution deleted by berkeman >>
Dec12-07, 11:57 AM   #4
Recognitions:
Homework Helper Homework Help
Points (1) and (2) that unplebeian mentions are often coined, the golden rules of op-amps and may be applied to these kinds of questions.
Using, the rule: input to an op-amp draws (essentially) no current, you can easily deduce what happens to Rs.
You can use the expression that unplebeian describes in point (3). However your own expression for Vo is equally valid and will agree in solution.
Thread Closed
Thread Tools
Similar Threads for: Non-Inverting Operational Amplifier.
Thread Forum Replies
Inverting Operational amplifier Engineering, Comp Sci, & Technology Homework 1
Inverting amplifier Electrical Engineering 4
Operational Amplifier (Voltage Follower) Electrical Engineering 6
a non-inverting amplifier Introductory Physics Homework 3
