| Thread Closed |
[SOLVED] Determine the mass of sodium chloride produced when 2.5 moles of chlorine ga |
Share Thread | Thread Tools |
| Nov27-07, 09:00 PM | #1 |
Okay...I know how to solve half the problem. I know how to balance the problem but I'm not sure what to do next. I'm really bad at this stuff.
Here's the question: Determine the mass of sodium chloride produced when 2.5 moles of chlorine gas reacts with sodium. Na + Cl2 NaCl (be sure to balance the reaction first!) And this is the balanced equation: 2 Na + Cl2 = 2 NaCl Anyone have any suggestions? |
| Nov28-07, 12:52 AM | #2 |
Assuming it is reacting with excess sodium, Chlorine becomes the limiting reagent.
So the moles of NaCl should be 5 moles (since 2 : 1 = 2 stoichiometric ratio). Using the formula: #of moles = mass(g)/molar mass Some basic algebra: Mass = 5 x (22.99 + 35.45) = 292.2 g Hmmm...doesn't look right.. Did something wrong, anyone correct me please? |
| Nov28-07, 01:03 AM | #3 |
Looks fine.
Keep in mind for the future that it is better to guide the OP through suggestions, questions and hints than to write up the complete solution. The former approach is often a much more effective teaching tool. And if you haven't already, please take a look at our posting Guidelines. |
| Nov28-07, 01:20 PM | #4 |
Thanks. Hopefully I'm remember that for the test. *fingers crossed* It seems easy enough but when you suck at this stuff, it's hard to remember everything. Thanks again. 8)
| Thread Closed |
| Thread Tools | |
Similar Threads for: [SOLVED] Determine the mass of sodium chloride produced when 2.5 moles of chlorine ga
| [SOLVED] Chemical Reaction between water and chlorine | Biology, Chemistry & Other Homework | 5 | ||
| Does the shape of the curve, that is produced in space by a mass, have a name ? | Special & General Relativity | 6 | ||
| Number of moles = volume/molar mass? | Biology, Chemistry & Other Homework | 19 | ||
| Miscellaneous calculation with moles, mass and gas volume | Biology, Chemistry & Other Homework | 3 | ||
| HELP solubility product determine solubility of lead 2 chloride mol/L and g/L | Biology, Chemistry & Other Homework | 2 | ||
