How Would Doubling Earth's Mass Affect the Moon's Orbit?
Doubling Earth's mass results in a significant alteration of the Moon's orbit. The gravitational force between Earth and the Moon increases, leading to a potential decrease in the orbital radius. Calculations indicate that while the gravitational force doubles, the Moon's angular velocity remains constant, suggesting it may transition to an elliptical orbit. The analysis requires applying the formula F=GMM/d² and considering both gravitational potential energy and kinetic energy to understand the new orbital dynamics.
  • Understanding of gravitational force calculations using F=GMM/d²
  • Knowledge of centripetal acceleration and its relation to orbital motion
  • Familiarity with concepts of gravitational potential energy and kinetic energy
  • Basic mathematical skills for deriving orbital radius formulas
  • Study the implications of changing mass on orbital mechanics
  • Learn about elliptical orbits and their characteristics
  • Explore the effects of gravitational potential energy on satellite motion
  • Investigate centripetal acceleration in varying mass scenarios
Astronomers, physicists, and students of orbital mechanics will benefit from this discussion, particularly those interested in gravitational interactions and orbital dynamics.
superlux1234
What would happen to the orbit of the moon if the Earth's mass were suddenly (magically!) to double? **Assume the orbit is initially circular
This is everything given in the question.
So, basically what I have come up with is using F=GMM/d^2 ... I have found that when the Earth's mass doubles, that the gravitational force also doubles. So at this point the moon will want to move closer to the earth, as the orbit will become... 3/4 of what it origionally was? When it does this, I was thinking that the moon will still have a large angular velocity (larger then is called for by its new orbit), so it will basically be sling-shot into an elliptical orbit maybe?
So... basically what I have decided so far is that the gravitational force doubles, and that brings the moon 1/4 closer to Earth ...
The maths indicates otherwise. That is that it will orbit at a larger distance from the "new" earth.
You have to work through the maths. Assume that the speed remains as previously (use the centripetal acceleration) and get a formula for the radius (distance between the Earth and the moon - which will change when the mass of the Earth changes) of a (circular) orbit as a function of the mass of the Earth and the speed of the moon.
The same result can be obtained by assuming the moon will enter an orbit where the gravitational potential energy remains unchanged (and the kinetic energy remains the same - that is the orbiting speed is unaltered).
