| Thread Closed |
Confused about how to solve this problem combining sinusoids please help |
Share Thread | Thread Tools |
| Dec4-07, 11:25 AM | #1 |
The text book problems states: y=cos3x +sin3x and you are to combine it to a single cos function and tell what effect the 3 has. The answer in the back of the book is given as sqrt2*cos(3x-pi/4) and that the 3 means the wave has a horizontal dilation of 1/3. 2. Relevant equations general solution for a sinusoid y = C+A*cosB(X-D) where C is the axis, A is the amplitude, B is the reciprocal of the period, X is the angle in radians and D is the phase displacement. 3. The attempt at a solution 1. find A using the pythagorean theorem: so from the original equation y=cos3x+sin3x, we get A=sqrt of 1^2+1^2 or the sqrt of 2 (because the coefficients in the above equation are both 1) 2. Find D by finding the inverse tan of 1/1, because the two coefficients in this prob. are both 1. So the inverse tan of 1 is pi/4. 3. Then I substitued pi/4 for D in the general sinusoid equation sqrt of 2 for A, giving me: y=sqrt2*cosB(x-pi/4) 4. I used the 3's from the original problem as B in my general equation. so now I have: y=sqrt2*cos3(x-pi/4) This is what I thought the answer should be....why does the correct answer have the 3 inside the parenthesis like this: y=sqrt2*cos(3x-pi/4)? It seems to me that the 3 should not only be distributed to the X, but should be outside the parenthesis so that it gets distributed over both X and D. Please help me understand where I'm going wrong. Thanks so much. ![]() 1. The problem statement, all variables and given/known data 2. Relevant equations 3. The attempt at a solution |
| Dec4-07, 02:46 PM | #2 |
Recognitions:
If you started with y=cos(x)+sin(x), you would get y=sqrt2*cos(x-pi/4), right? Now, to turn y=cos(x)+sin(x) into y=cos(3x)+sin(3x), you replace every x by 3x. You don't replace every x-pi/4 by 3x-3pi/4; that would be equivalent to replacing every x by 3x-pi/2.
| Dec4-07, 03:09 PM | #3 |
If 3 is the reciprocal of the horizontal dilation, how can I simply place it into the (x-D) portion of the equation? Thanks guns4monkeys |
| Dec4-07, 06:34 PM | #4 |
Recognitions:
I just explained the correct answer using a very general math principle. You've apparently been taught some set of rules for these kinds of combinations. These rules must agree with general math principles, or they're wrong. In general, you're much better off trying to understand the general principle, rather than learning how to apply a set of rules.
| Dec4-07, 08:01 PM | #5 |
| Dec4-07, 09:22 PM | #6 |
Recognitions:
I'm sorry, but I don't know what's confusing you; I don't know what you mean by "the solution with the 3X in the parenthesis and nothing in the position of B".
| Dec4-07, 09:41 PM | #7 |
Thanks for trying to help me.
Guns4monkeys |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Confused about how to solve this problem combining sinusoids please help
| how do you solve problem you cannot solve? | Academic Guidance | 16 | ||
| Calc based Kinetics problem... (Very easy to solve with physics- confused with calc0 | Introductory Physics Homework | 7 | ||
| Sinusoids | Precalculus Mathematics Homework | 1 | ||
| sinusoids | Precalculus Mathematics Homework | 5 | ||
| Using cramer's Rule to solve for x2, i'm confused on this example! | Calculus & Beyond Homework | 2 | ||
