Thread Closed
Magnetic field of rotating cylinder
Share Thread Thread Tools
Dec9-07, 11:32 AM   #1
The problem is to find the magnetic field within a rotating cylinder (infinitely long) that has on its surface a given surface charge density p. I made a picture of the problem to illustrate this. The only hint given: "the magnetic field outside the cylinder is zero.
2. Relevant equations
Sorry, I cannot use Latex, but:
integral(B,ds) = u0*integral(J,da) where
B is the magnetic field, ds the vector line element, J the current density, da the vector area element.
3. The attempt at a solution
Well, to be cleary, I can solve this problem, but I do not understand a very basic thing.
First I argued by symmetry, that the magnetic field can only be in direction of the angular frequency vector w. Then I took a curve c, illustrated in my picture and now I want to apply the integral law I have written above to this curve c.
I know the left hand side of the integral, which is simply (given that the curve has lengt L):
B*L,
Now I want to calculate the right hand side. Doing so, I first need J. logically:
|J|=(p/(2*pi*R))*(w*R) where (w*R) = v is simply the velocity.
Up to here all is quite easy, but now I have some questions:
i) Is it correct, that the J vector is the tangential vector to the outer surface of the cylinder perpendicular to the angular frequency vector w?
ii) The integral law states that I have to integrate J over the area enclosed by the curve c. But this doesn't seems to be correct. I mean, the area within the cylinder and enclosed by the curve c would then be (R-r1)*L and outside undefined. So over which area do I have to integrate and WHY?
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Galaxies fed by funnels of fuel
>> The better to see you with: Scientists build record-setting metamaterial flat lens
>> Google eyes emerging markets networks
Dec9-07, 02:12 PM   #2
Recognitions:
Gold Membership Gold Member
Homework Helper Homework Help
Is it a hollow cylinder? Also, do you have a surface current flowing only on the outside of the cylinder, or is it a volume current?
Dec9-07, 03:12 PM   #3
Well, I think we can assume the cylinder to be a perfect conductor carrying only a surface charge density at its outside. So inside there will not be any current.
Dec10-07, 08:20 PM   #4
Recognitions:
So, you'll only need to calculate the net current enclosed by the curve C you drew. If [tex]\sigma[/tex] is the surface charge density, then the surface current will be [tex]K=\sigma v = \sigma \omega R[/tex]. From this, you can find the current enclosed by the loop and the magnetic field inside.
Dec11-07, 05:51 AM   #5
Ah, so you mean I have to integrate the surface current density K (unit A/m) over the line my curve intersects the cylinder? So I get K*length(curve) = K*L.
Dec11-07, 10:31 AM   #6
Recognitions:
Quote by Kruger View Post
Yeah, looks right.
Dec12-07, 05:17 PM   #7
Ah, ok, then I understand it now. I think the first thing I were trying to do was integrating an object, namely the current density J, which is simply everywhere zero except at the boundaries of the cylinder over an area which intersects the current density vector J perpendicular. This cannot really work, because then J would be of zero measure for the integral of J over the area which is enclosed by the curve I have drawn (because with respect to the integral J*d(area), J is just defined on a line, namely the intersection of my rectangular area with the cylinder and zero elsewhere).
<--- This seems to be written in a strange manner, but well, this was just what confused me.
Thank you for help.
Thread Closed
Thread Tools
Similar Threads for: Magnetic field of rotating cylinder
Thread Forum Replies
Magnetic field of a cylinder with an offset hole Introductory Physics Homework 16
E.m.f across the ends of a rod rotating in a magnetic field Classical Physics 2
A rotating magnetic field. Does any one know how this is done? Electrical Engineering 2
Magnetic Field of a cylinder Advanced Physics Homework 0
Torque on a rotating charge due to a uniform magnetic field Advanced Physics Homework 5
