Is the Pauli Exclusion Principle Universally Applicable?
The discussion revolves around the applicability of the Pauli Exclusion Principle (PEP) in quantum mechanics, particularly concerning identical fermions such as electrons. Participants explore the implications of the principle, its restrictions, and its relevance in various contexts, including atoms and larger systems.
  • Some participants express confusion about the statement that "no two identical fermions can be in the same quantum state," questioning its universal applicability.
  • One participant argues that while the PEP has no restrictions, the localization of the wavefunction is crucial in distinguishing states of electrons in different locations.
  • Another participant suggests that two electrons in the same atom could theoretically occupy the same quantum numbers if they are not in the same spatial location, raising questions about the interpretation of the PEP.
  • A later reply clarifies that the wavefunction's localization is key, asserting that two electrons in the same state of the same atom would have identical localization.
  • Some participants discuss the mathematical formulation of the PEP, noting that the antisymmetry of the wavefunction implies that electrons cannot occupy the same state if they are indistinguishable.
  • One participant raises a question about the implications of rotations in the coordinate system on the quantum states of electrons, suggesting that this could allow multiple electrons to occupy the same state.
  • Another participant counters this by explaining that rotations do not lead to orthogonal states, thus not allowing multiple electrons to occupy the same energy level.
  • There is a discussion about whether the PEP applies only to electrons within a single atom or universally to all identical fermions, with some participants asserting that it applies broadly while others express uncertainty.
  • One participant highlights the importance of indistinguishability in the context of the PEP, suggesting that this is a critical factor in determining whether the principle applies.
Participants do not reach a consensus on the applicability of the PEP across different contexts. There are multiple competing views regarding its restrictions and the implications of localization and indistinguishability.
Some discussions touch on the mathematical foundations of the PEP and its implications in various physical systems, but these points remain unresolved and depend on specific assumptions about the systems being considered.
madness
I've just been reading my notes on quantum mechanics and got to the Pauli exclusion principle. The way it was explained makes no sense to me. It says "no two identical fermions can be in the same quantum state". Surely there are some restrictions to the applicability of this statement? It doesn't make sense to say that no two electrons in the entire universe can occupy the same quantum state. Any help would be much appreciated.
No. There are no restrictions on the exclusion principle. But, don't forget that states may be distinguished by localization. That is, an electron in the ground state of a Hydrogen atom in the sun is not in the same state as an electron in the ground state of a Hydrogen atom on Mars.
Surely in that case two electrons in an atom can have the same quantum numbers provided they don't occupy the same spatial location? Where is the distinction between two electrons in an atom or two on different planets if there is no restrictions on the applicability of the Pauli exclusion principle?
The distinction is that what is relevant is the localization of the wavefunction. The wavefunction of an electron in an atom is localized to the vicinity of and centered on that atom. It's shape is entirely determined once you know the quantum numbers of its state. So, two electrons in the same state of the same atom would necessarily have the same localization. Unless this is the case, the electrons are simply not in the same state.
It didn't make sense to me either. The claim that the wave function must be antisymmetric in the exchange of electrons, that means psi(x1,x2) = -psi(x2,x1), is mathematically well defined claim. The claim "electrons cannot be in the same state" seems to be a special case of this. It only makes sense if you can assume that the electrons feel the identical potential.
For example, I wouldn't know what it would mean for electrons to be a in a different or in the same state, if we didn't ignore the interactions of the electrons themselves.
If what is relevant is the localisation of the wavefunction, then why not choose the system to be two atoms, or a galaxy? Then the wavefunction would include all electrons in the system, and no two electrons in the system could occupy the same quantum state.
Ok i think i understand better now. The last post doesn't make sense since all the electrons are in different spatial positions, whereas the wavefunction of a single atom specifies the spatial position exactly wrt the nucleus.
Ok so if there is a wavefunction for an electron which depends on angle as well as distance from the nucleus, then surely a rotation by an arbitrary angle will give another quantum state, since there is nothing special about the coordinate system chosen. Wouldn't this allow more than one electron to occupy a state with the same quantum numbers?
Can nobody answer the last question? I don't think there is anything wrong with the question. Given the earlier responses in the thread it seems an obvious question to ask.
I thought the Pauli exclusion principle applied to electrons within a given atom. Clearly all atoms of a given element and in the ground state have the same electron configuration. Basically, what PEP means is that no two or more electrons in a given atom will have the same set of quantum numbers.
Thanks Astronuc, I thought that might be the case too, but I'm unsure why the PEP would only apply to atoms. I was told earlier in the thread that it applies to every identical fermion in the universe, with position being a factor, but then I haven't had my above question on that explained yet.
If you rotate by an arbitrary value in [itex]\phi[/itex], you will, at worst, add an overall phase to the wavefunction. This can be absorbed into the normalization; so, it makes no physical difference. If, however, you rotate in [itex]\theta[/itex], you are effectively changing your z-axis; so, you're transforming into a superposition state that mixes values of m. In neither case will an arbitrary rotation allow you to end up with a state orthogonal to your starting one. So, no, such a rotation will not allow you to fit arbitrarily many electrons into a given energy level.
Indeed, the Pauli Exclusion Principle applies to two or more electrons or two or more protons or two or more of any of the same brand of fermions. Let's work with just electrons -- representative Fermions if you will. The basic stricture of the PEP is: any multiple-electron state must be antisymmetric under the interchange of any two electrons. This necessarily prevents two electrons from being in the same state -- for example, suppose we are interested in the atomic structure of Helium, and we'll use hydrogen wave functions as our basis. A one-electric state is characterized by a complete set of quantum numbers, and for hydrogen we'll use the standard set: orbit number, n, orbital and spin angular momenta L , S =1/2; Lz and Sz, the angular projections on the z-axis. The Helium state with 2 s state electrons (2s for short) with 2Sz=1 or -1. This state is impossible according to the Pauli Principle. It is symmetric under electron interchange.
Why the PEP? The reason is a bit arcane, and is best seen within the context of QFT. In order to guarantee that all non-interacting particles have positive energy (0 is allowed), the particles involved must either obey canonical commutation rules or canonical anti-commutation rules. The proof can be found in many texts, and, probably, in Google, or other internet venues.
And, of course, the major triumph of the PEP is the explanation of why the Periodic Table is as it is.. Atomic shell structures would be otherwise if not for the PEP.
Regards,
Reilly Atkinson
Note: the PEP applies to all electrons. However, if you include all these other electrons, you will find their influence is small, due mainly to distance.
I know this thread is old, but I have brought it back up because the answers I got seem inconsistent with new things i have learned. You say that the reason the PEP doesn't apply to electrons in separate atoms is that the occupy different positions in space. If this is the case then how can it be applied to electrons in a fermi gas, as is done in statistical mechanics?
… indistinguishable … that's what you are! … or was it you? …
Hi madness! :smile:
Isn't it simply that, for the Pauli exclusion principle, the electrons have to be indistinguishable?
Two electrons in the same shell and with the same spin round the same atom are indistinguishable.
Two electrons in the same shell and with the same spin round different atoms aren't.
(erm … I don't know anything about fermi gases … :redface:)
two electrons are clearly indistinguishable no matter what. how do you tell the difference between them?
if you have a seperable potential in an atom, ie the electron electron interaction is ignored. then the pauli exclusion principle holds, the idea of fermions and bosons is that one is symmetric and one anti-symmetric, now what does this condition mean?
well (use y instead of psi) y=y1y2-y2y1
now if the two electrons have the same quantum numbers that means y1=y2
hence y=0 and this combination doesn't exist, hence the PEP. this holds as long as you can separate your hamiltonian into something that looks like H1+H2=H
if you can't do that then the PEP would have no reason to hold as you can't use separation of variables.
unless there is some stronger form which holds for non-seperable hamiltonians?
would that make electrons distinguishable , in principle?
… I have PET electrons which I keep in separate boxes …
I give them names, and then follow their careers in the electronic media! :smile:
Unless they're hanging out with their buddies in the p-shell, in which case I can't because… they're indistinguishable!
(I think it has something to do with being in the same Hilbert space … :confused:)
It may be to do with their indistinguishability. Electrons are only (at least in my stat mech course) considered indistinguishable when they are not localised. For example atoms with fixed positions in a crystal are distinguishable but in a gas are not. Perhaps electrons in a single atom are indistinguishable but electrons in separate atoms are distinguishable. I would be interested to see if this is provable from QM.
I think you've misconstrued what I said some months back. My whole point was that the Pauli exclusion principle does apply between any two electrons. But, that the equivalent energy levels in two atoms are not the same state, which can be understood by recognizing that they have different localization. If two states have different representations in the position basis, then they must be different states.
As has been pointed out by several people on this thread, the Pauli exclusion principle can be seen as a consequence of the necessity that all multi-electron states be antisymmetric under the exchange of any pair of electrons. If two electrons were in identical states, the combined wavefunction would necessarily be symmetric under exchange of these two electrons, since it wouldn't be possible to tell what change had been made. The only way for the wavefunction to be simultaneously symmetric and antisymmetric under the exchange is for it to be identically 0.
I'd imagine the resolution to the distinguishable indistinguishable bit is probably an approximation.
ie. if you have two electrons separated by a light year then you could approximate their evolution as being distinguishable. If the electrons are confined in the same potential and are relatively close to each other than this approximation brakes.
I suppose the statement that would best describe this would be something like
given a many-body problem in QM, the particles can be approximated as being distinguishable if you can make the claim "this measurement corresponds to this particle" and the probability that the measurement corresponds to a different particle is small.
how far appart will make them distinguishable? light year? 0.1 light year? and shouldn't that be included in the mathematics of QM?
Parlyne, I understand that two electrons in different atoms have different localisation. My point was that in a fermi gas they also have different localisation but are the Pauli exclusion principle is still applied.
  • · Replies 17 ·
