Learn How to Build a 2-Stage JFET Amplifier: A Comprehensive Guide
  • Thread starter Thread starter Windwaker2004
    Amplifier
The discussion revolves around the setup and analysis of a 2-stage JFET amplifier. Participants explore various configurations, performance characteristics, and the theoretical underpinnings of using JFETs in amplifier design.
  • One participant seeks guidance on setting up a 2-stage JFET amplifier, noting previous experience with BJT amplifiers.
  • Another participant questions the necessity of a 2-stage JFET amplifier and suggests that FETs are not typically used for high gain, proposing a configuration that includes BJTs for certain stages.
  • A participant acknowledges the limitations of JFETs compared to BJTs for voltage gain but expresses a desire to practice different configurations and seeks help with circuit setup and equations.
  • A later reply challenges the advice given about multistage amplifiers, emphasizing the difficulty of ensuring stability in three-stage designs and suggesting that high gain can often be achieved with a single stage. This participant also notes that the choice of output stage should depend on the specific load requirements.
Participants express differing views on the necessity and configuration of a 2-stage JFET amplifier, with no consensus reached on the best approach or the role of BJTs versus JFETs in achieving desired performance characteristics.
Participants mention various assumptions regarding amplifier stability, gain requirements, and the nature of load impedance, which may influence the design choices discussed.
Windwaker2004
Hey guys,
I am curious on how to set up a 2 stage JFET amplifier. I've reviewed some analysis on 2 stage BJT amplifiers as well as 2 stage BJT/JFET amplifiers but I cannot find anything on how to use 2 JFETs. Any help would be greatly appreciated. Thank you!
Any reason why you need a 2 stage JFET? Are you looking explanations on how to get equations on input impedance, output impedance, gain, etc. You shouldn't bother yourself with input impedance as FETs aren't lacking in that category.
Generally in a multistage amplifier, you'd use a FET as an input stage, For example, in a three stage amp, your first stage should have high input impedance, so you'd used a FET. The middle stage can used for gain. Its not that wise to use a FET solely for high gain. Remember the issue with FETs and transconductance. The middle stage can be a common emitter. Finally, you'd want low output impedance. Which BJT configuration has low output impedance?
thanks a lot for the reply!
I realize JFETs aren't good compared to BJTs for voltage gain. I am just practicing different configurations, in this case 2 gain stages, and would like to know how to set up the circuit and get the equations. I do understand JFETs but need some help in this scenario. Thanks again!
I have to disagree with most of what ranger said...
It's extremely hard to guarantee stability in three-stage amplifiers (if they're used in feedback loops), so don't build them. You can easily obtain a gain of ~2500 per stage with FETs, and there's rarely a need for gains higher than 2500^2. Most designs can actually be realized with a single stage, in fact. If you do use two stages, you should generally make most of your gain in the first stage -- this will permit your output swing and dynamic range to be larger.
Depending upon your application, you may or may not want low output impedance. The actual choice of output stage would depend upon the nature of the load (resistive, capacitve, etc.).
You'd need to tell us quite a bit more about your specific requirements for us to be able to provide you any more specific help.
- Warren
15K
  • · Replies 21 ·
  • · Replies 27 ·
