Vertical/Horizontal Asymptotes
  • Thread starter Thread starter tachu101
The function f(x)=(4x^2+25)/(x^2+9) has a horizontal asymptote at y=4 and no vertical asymptotes. The absence of vertical asymptotes is due to the denominator x^2+9 never equating to zero for real values of x, indicating that the function remains defined across all real numbers. In contrast, vertical asymptotes apply only to real functions, while poles are the equivalent concept in complex analysis.
  • Understanding of rational functions
  • Knowledge of asymptotic behavior in calculus
  • Familiarity with polynomial expressions
  • Basic concepts of complex numbers
  • Study the properties of rational functions and their asymptotes
  • Learn about the concept of poles in complex analysis
  • Explore limits and continuity in calculus
  • Investigate the behavior of functions at infinity
Students studying calculus, particularly those focusing on asymptotic analysis and rational functions, as well as educators seeking to clarify these concepts for their students.
tachu101
Find the Vertical and horizontal asymptotes of this function
I think that the horizontal asym. is y=4
But the Vertical if (x^2+9)=0 then x is an imaginary number. So is the asym. (3i) or does the asym not exist?
You are right on horizontal. For the second one, no, does not exist. Vertical asymptotes apply to real functions. For complex, the corresponding concept is called a 'pole'.
For (real-valued) rational functions of polynomials, you will have a vertical asymptote where the denominator is zero, unless the numerator is also zero there. (If that happens, you have to look for cancelling terms or look at the limit of the ratio as x approaches the value where both "top" and "bottom" are zero.)
In the case of your function, the denominator can never be zero (for x real), so the rational function is always defined. So it will have no vertical asymptotes.
  • · Replies 21 ·
