Theoretical mechanics question
The discussion revolves around the relationship between Lagrangian and Hamiltonian formulations in theoretical mechanics, specifically focusing on the existence of corresponding transformations between these two frameworks. Participants explore whether every canonical transformation in Hamiltonian mechanics has a corresponding transformation in Lagrangian mechanics and the conditions under which one can transition from Lagrangian to Hamiltonian systems.
  • Some participants propose that not every canonical transformation in Hamiltonian mechanics corresponds to a transformation in Lagrangian mechanics, citing that point transformations are a subset of canonical transformations.
  • One participant provides an example involving a particle under a central force to illustrate that a non-point canonical transformation does not yield a corresponding Lagrangian transformation.
  • There is a discussion about the equivalence of Lagrangian and Hamiltonian descriptions, with some participants questioning how all Hamiltonian systems could have corresponding Lagrangian systems if the set of transformations is larger in Hamiltonian formalism.
  • Another participant suggests that performing a non-pointwise coordinate transformation may result in a completely new Lagrangian when transitioning back to the Lagrangian formulation.
  • Some participants express skepticism about the ability to always transition from Lagrangian to Hamiltonian systems, emphasizing the condition of the Hessian matrix being non-singular for the Legendre transformation to be valid.
  • One participant mentions a related discussion in another thread about systems that may not conform to the standard transition from Lagrangian to Hamiltonian frameworks.
Participants express disagreement regarding the ability to always transition from Lagrangian to Hamiltonian systems, with some asserting that it is not universally possible due to specific conditions. The discussion remains unresolved, with multiple competing views on the nature of transformations between the two formulations.
Limitations include the dependence on the definitions of transformations and the conditions under which Legendre transformations can be applied, particularly regarding the non-singularity of the Hessian matrix.
jostpuur
Here's a simple question. Anyone who knows the answer can save me from some effort by telling the answer.
For arbitrary canonical transform [itex](q,p)\mapsto (Q,P)[/itex] in the Hamilton's formulation, does there always exist a corresponding transformation [itex]q\mapsto Q[/itex] in the Lagrange's formulation? By corresponding transformation, I mean such transformation, that when we move from the Lagrange's system [itex]L(Q,\dot{Q})[/itex] to the Hamilton's formulation, we get the same [itex]K(Q,P)[/itex] as from the original canonical transform.
Another question (or perhaps the same): I know that we can always move from Lagrange's formulation to the Hamilton's formulation, but is the converse true. Do such Hamiltonian systems exist, that you cannot achieve by starting from some Lagrangian system?
jostpuur said:
... For arbitrary canonical transform [itex](q,p)\mapsto (Q,P)[/itex] in the Hamilton's formulation, does there always exist a corresponding transformation [itex]q\mapsto Q[/itex] in the Lagrange's formulation? By corresponding transformation, I mean such transformation, that when we move from the Lagrange's system [itex]L(Q,\dot{Q})[/itex] to the Hamilton's formulation, we get the same [itex]K(Q,P)[/itex] as from the original canonical transform.
The answer generally is No!
Transformations [itex]q\mapsto Q[/itex] (point transformations) are a subclass of the canonical transformations [itex](q,p)\mapsto (Q,P)[/itex].
After all, canonical transformations are between [itex]2\,n[/itex] variables [itex](q,p)[/itex], while point tranformations are between [itex]n[/itex] variables [itex]q[/itex].
Take or example the 1D problem, of a particle moving with the aid of a central force
[tex]f(x)=-\frac{k}{x^2}\Rightarrow V(x)=\frac{k}{x}[/tex]
Then the Lagrangian and Hamiltonian functions are
[tex]\mathcal{L}=K-V\Rightarrow\mathcal{L}=\frac{1}{2}\,m\,\dot{x}^2-\frac{k}{x}, \quad \mathcal{H}=K+V\Rightarrow\mathcal{H}=\frac{1}{2\,m}\,p^2+\frac{k}{x}[/tex]
Perform now the non-point canonical transformation
[tex](q,p)\mapsto (-P,Q), \quad \mathcal{H} \mapsto \mathcal{H}', \quad \mathcal{L} \mapsto \mathcal{L}'[/tex]
and you will see that there is no function [tex]q=f(Q)[/tex] which achieves the transformation [tex]\mathcal{L} \mapsto \mathcal{L}'[/tex].
Of course, if the canonical transformation happens to belong to the subclass of point transformations then the answer is obviously yes.
The Lagrangian and Hamiltonian descriptions are equivalent, you can pass from one to the other by Legendre's transformation.
There is something that doesn't make sense in this. If the set of coordinate transformations in the Hamiltonian formalism is larger than the set of coordinate transformations in the Lagrangian formalism, how could all Hamiltonian systems have a corresponding Lagrangian system?
Or then I got it. If we move from Lagrangian formulation to Hamiltonian formulation, perform a non-pointwise coordinate transformation, and move back to Lagrangian formulation, we just get completely new Lagrangian?
That's the point I was trying to establish at my 1st answer! :smile:
I don't think one can always move from the Lagrangian to the Hamiltonian system. The condition for which it's possible to make a legendre transformation to the hamiltonian framework is when the hessian matrix represented by
[tex]\left(\frac{\partial^2 L}{\partial \dot{q}_i \partial \dot{q}_j}\right)[/tex]
is non-singular.
For example, consider the Lagrangian
[tex]\mathcal{L} =\frac{1}{2} (\dot{q}_1-\dot{q}_2)^2} + V(q_1,q_2)[/tex]
is non-singular.
By strange coincidence, me and Rainbow Child were just talking about system like this in the other thread Fermion oscillator
And yes it was a mistake from me to say that we can always move from L to H (in the standard manner).
  • · Replies 25 ·
  • · Replies 20 ·
10K
