Is the Electric Field Always Zero on an Imaginary Surface Containing No Charge?
The discussion revolves around the behavior of the electric field on an imaginary closed surface that contains no charge. Participants are exploring whether the electric field is always zero on such a surface and under what conditions it may not be.
  • Some participants consider specific scenarios, such as the effect of a point charge outside the surface, and question how the electric field behaves in those cases. Others raise questions about the interpretation of the electric field on the surface, including whether it refers to an average value across the surface.
The discussion is ongoing, with participants sharing different perspectives and attempting to clarify their understanding of the electric field in relation to the imaginary surface. There is no explicit consensus yet, but various interpretations and questions are being explored.
Participants are grappling with the implications of the absence of charge within the surface and how that affects the electric field, as well as the definitions and assumptions related to electric field measurements.
geronimo8
A certain region of space bounded by an imaginary closed surface contains no charge.
Is the electric field always zero on the surface? If not, under what circumstances is it zero on the surface?
Φ = Qenclosed÷εo = EA
Since the imaginary surface need no any material object. I think the E refres to the inside surface, so it is not zero...
Imagine the field produced by a single positive point charge at the origin, you know what the field looks like. Now, draw your surface as a sphere that does not include the origin. What does the field look like on the surface? Is it zero?
I can't imagine that clearly... *sigh* sorry...
One question related to this problem: When you get asked about the electric field on the surface is it the average electric field over the surface?? I mean, in the case of a sphere, only when having the charge in the center will you have the same electric field all throughout the surface...
  • · Replies 26 ·
  • · Replies 83 ·
