Thread Closed
Finding resultant force
Share Thread
Dec18-07, 06:33 PM   #1
Recognitions:
Gold Membership Gold Member
Okay, I am only allowed to use law of cosines and sones to find the resultant force F_r
I am having a hell of a time finding a usable angle after drawing my parellelogram..so obviously I am in need of sleep.
What am I missing here? (pic is clickable)
Casey
PhysOrg.com science news on PhysOrg.com
>> City-life changes blackbird personalities, study shows
>> Origins of 'The Hoff' crab revealed (w/ Video)
>> Older males make better fathers: Mature male beetles work harder, care less about female infidelity
Dec18-07, 06:45 PM   #2
Recognitions:
I know I need to isolate a triangle, but I really suck at similar triangles when they are not necessarily right triangles.
Dec18-07, 06:46 PM   #3
Mentor
Draw yourself a diagram where you add the vectors (head to tail addition). The two vectors are the two sides of a triangle. You should be able to identify the angle between them and apply the law of cosines to find the third side of the triangle, which will be the resultant.
Dec18-07, 06:47 PM   #4
G01
Recognitions:
Homework Helper Homework Help
The 120 degree angle should be the angle corresponding to your resultant vector in the triangle. For the other angles:
HINT: What is the angle between the 80lb force and the -x axis? Does this help you find another angle in your parallelogram?
Dec18-07, 06:48 PM   #5
Recognitions:
Is the angle between them by any chance 60 degrees? In the parellepgram 2(120)=240 leaving 120/2 to give me four angles that add to 360
Dec18-07, 06:50 PM   #6
Mentor
Quote by Saladsamurai View Post
Yes. (Assuming you're talking about the triangle I referred to.)
Dec18-07, 06:51 PM   #7
Recognitions:
I'll be back in 20 minutes. All of the theological students just showed up at StarBucks and I can't take their banter.....I'm going home.
Casey
Quote by Doc Al View Post
Angle between 60 and 80 with tail of 60 at tip of 80.
Dec18-07, 06:53 PM   #8
Mentor
Run for it, man!
Dec18-07, 07:43 PM   #9
Recognitions:
I made it home!
Thanks Doc and G01! I am taking this Statics course over X-mass break :points gun into mouth and fake blows brains out:
So is the general approach to these to use the fact that vectors can be moved around to redraw the scenario in a manner that helps to generate more information from the given info?
Casey
Dec18-07, 07:47 PM   #10
Mentor
Yes. When adding vectors, you can move them around at will as long as you keep the magnitude and direction the same.
Thread Closed
Similar discussions for: Finding resultant force
Thread Forum Replies
Finding the direction of the resultant vector of three vectors? Introductory Physics Homework 10
Resultant Force Introductory Physics Homework 4
Finding the resultant force Introductory Physics Homework 7
finding a resultant Introductory Physics Homework 11
Finding the Resultant Introductory Physics Homework 2
