How Do You Calculate Total Voltage and Current in Mixed Resistor Networks?
The discussion focuses on calculating total voltage and current in mixed resistor networks, specifically involving a 12-ohm resistor in parallel with an 8-ohm and 16-ohm series combination. The total resistance (Rt) is determined to be 8 ohms, leading to a total current (It) of 6 A when a voltage of 48 volts is applied across the 8-ohm resistor. Additionally, for a second scenario with 1.95-ohm and 0.05-ohm resistors in parallel, the current through each resistor is calculated to be 25.64 A and 1000 A, respectively, under a total current of 50 A.
  • Understanding of Ohm's Law (V = IR)
  • Knowledge of series and parallel resistor combinations
  • Familiarity with calculating equivalent resistance
  • Ability to apply current division principles
  • Study the calculation of equivalent resistance in complex resistor networks
  • Learn about current division in parallel circuits
  • Explore voltage division in series circuits
  • Review practical applications of Ohm's Law in electrical engineering
Electrical engineering students, hobbyists working on circuit design, and anyone seeking to understand resistor networks and current calculations in practical applications.
jam7cacci
hi! I need some assistance regarding my assignment. hope there's anyone who could help me out. the questions are:
1.a. a 12 ohms resistor is connected in parallel with a series combination of resistors of 8 ohms and 16 ohms. if voltage drop across the 8 ohms resistor, is 48 volts. Determine the total impressed voltage and total current. Vt=? It=?
1.b. Relevant equations
V = IR; I=V/R
1.c. The attempt at a solution
so... first i have to get the total resistance to get the total current and voltage right? (Please correct me if I'm wrong. thanks! :D)
R12 = 8ohms + 16ohms = 24ohms
1/RT = 1/R12 + 1/R3
1/RT = 1/24 + 1/12ohms
1/RT = 1/8 ohms
Rt = 8 ohms
here's the part where I'm totally confused
It = Vt/Rt
It = 48Volts / 8 ohms
It = 6 A
Vt = 48? (i really don't know how to solve for the total voltage)
2.a. 2 resistors 1.95ohms and 0.05ohms are connected in parallel and takes a total current of 50V. What is the current in each resistor?
2.b. Relevant equations
I1 = It
I1 = V1/R1
2.c. The attempt at a solution
I1 = 50V / 1.95ohms
I1 = 25.64 A
I2 = 50V / 0.05ohms
I2 = 1000 A
voltage is the same for all when in parallel
current is the same for all when in series.
(ie: when you use the meter to emasure voltage, you put the probe across 2 points hence the probe is in parallel with component, but when you measure current you cannot do the same, need to make it part of the circuit)
for first part, find voltage drop across 8 and 16, then voltage across both of that is same as 12ohm (ie: if 48v across 8 ohm, and since 8 ohm in series with 16 and they share same current, how much is voltage across 16ohm, then what is the total voltage across 8series16, this is your answer)
for 2nd, you need to find the equivalent resistance, then find current
for 2nd, how does it take total current 50V? you mean 50A? do a current divider
least resistance means more current flow in that direction
  • · Replies 21 ·
