Thread Closed
Regarding the conversion of kinetic energy to mass
Share Thread Thread Tools
Dec23-07, 02:15 AM   #1
According to the theory of relativity, in the case of two particles of mass m and kinetic energy k colliding, the mass of the two particles together after the collision is greater than the sum of the two particles. It is claimed that thus the kinetic energy is converted to mass. How is this so? What kind of mass appears? In what form is this mass?
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> King Richard III found in 'untidy lozenge-shaped grave'
>> Google Drive sports new view and scan enhancements
>> Researcher admits mistakes in stem cell study
Dec23-07, 01:45 PM   #2
Mentor
I think that depends on the specific particles involved. If you have a >1.1 MeV photon colliding with a nucleus then the extra mass can be in the form of an electron-positron pair. If you have two lumps of clay then the extra mass will typically be in the form of heat.
Dec24-07, 05:35 AM   #3
Recognitions:
Gold Membership Gold Member
Retired Staff Staff Emeritus
Quote by DaleSpam View Post
I agree with the first part of that, but heat is NOT mass!
Dec24-07, 12:22 PM   #4
Mentor
Quote by HallsofIvy View Post
heat is NOT mass!
A hot object has more energy in its rest frame than a cold object. This increases the timelike component of the object's 4-momentum and therefore also increases the norm of the 4-momentum. The norm of the 4-momentum is proportional to the mass. Heat may not be mass exactly, but adding heat increases the mass of an object.
Dec24-07, 12:36 PM   #5
Recognitions:
I agree with you that an increase in temperature will result in an increase in the invariant mass of an object. However, heat is not temperature and we should always maintain a clear distinction.
Dec24-07, 12:53 PM   #6
Mentor
Quote by Hootenanny View Post
You are absolutely correct, I was unclear.
Dec24-07, 04:41 PM   #7
So it increases mass how though? WHat is the form of this mass? The electron-positron pair? How does this hapen? Where does the electron and positron come from?
Dec24-07, 04:52 PM   #8
Recognitions:
Quote by Stellar1 View Post
Higher temperature basically just means the molecules have a higher average velocity in their random movements, and so this makes the object harder to accelerate (i.e. it requires more energy) in the same way that it's harder to accelerate individual objects moving at a significant fraction of c in your frame. Basically this is a consequence of the fact that the higher the velocity, the greater the increase in energy for a given incremental increase in velocity, according to the equation:
[tex]E^2 = m^2 * c^4 + p^2 * c^2[/tex]
...where p is the object's relativistic momentum, [tex]p = \frac{mv}{\sqrt{1 - v^2/c^2}}[/tex]
Dec24-07, 07:44 PM   #9
Mentor
They come from the energy of the photon. An electron has a mass of 511 keV, so if a single photon has an energy of at least twice that, or just over 1 MeV, then it has enough energy to convert to the mass of two electrons by e=mc^2. However, a photon is uncharged, so for charge conservation it is necessary to produce an electron and a positron instead of two electrons.
Dec24-07, 11:06 PM   #10
Recognitions:
But Stellar1's question was in reference to your statement about heat increasing mass...the fact that two lumps of clay become more massive when some of their kinetic energy is converted into heat which raises their temperature has nothing to do with the creation of new particles.
Dec25-07, 08:49 AM   #11
Mentor
Quote by JesseM View Post
Stellar1's question had two parts. You answered the part about how thermal energy made an object more massive, so I answered the part about new particles. That is why I quoted only the specific part of his quesiton that I was answering. Your comments about thermal energy and inertia were concise and complete; I didn't have anything useful to add on that subject.
Dec25-07, 09:26 AM   #12
Recognitions:
I don't disagree with any part of your answer, but I interpreted Stellar1's question differently. In response to your comment "Heat may not be mass exactly, but adding heat increases the mass of an object", Stellar1 wrote: "So it [i.e. heat] increases mass how though? WHat is the form of this mass? The electron-positron pair?" When Stellar1 asked "what is the form of this mass" I thought the question was still about the mass added through heat, and that Stellar1 was confused, thinking that the mass added through heat was in the "form" of an electron-positron pair.
Dec25-07, 10:11 AM   #13
Mentor
Hi Stellar1, just to be clear, the form of the extra mass will be different for different kinds of collisions. The high-energy photon creating an electron-positron pair was an example where new massive particles could be created. The thermal energy in the lumps of clay was a completely separate example where no new massive particles were created, but the inertia of the system was increased by the increased temperature.
Dec25-07, 12:38 PM   #14
Heat is one of two modes of energy transfer; the other being work. Heat is not energy.
Dec31-07, 09:17 AM   #15
Mentor
The photons also have momentum and energy, so a "photon gas" has inertia and therefore mass. In this case the extra inertia would be due to the fact that the blue-shifted photons striking the rear of the accelerating cavity would have more momentum than the red-shifted photons striking the front.
Thread Closed
Thread Tools
Similar Threads for: Regarding the conversion of kinetic energy to mass
Thread Forum Replies
Energy<>Mass conversion General Physics 10
Transfer and Conversion of pressure to Energy (Kinetic) General Physics 0
Conversion of mass to energy Special & General Relativity 9
Conversion of mass to energy Atomic, Solid State, Comp. Physics 1
Conversion of mass to energy High Energy, Nuclear, Particle Physics 0
