| Thread Closed |
Complex field lagrangian |
Share Thread | Thread Tools |
| Dec27-07, 04:05 PM | #1 |
Consider a complex field f (x, t) defined over the full four dimensional space-time. The Lagrangian is: [tex]\frac{i}{2}(f*\frac{df}{dt}-f\frac{df*}{dt}) - \frac{1}{2}[(\frac{df*}{dx})(\frac{df}{dx})+(\frac{df*}{dy})(\frac{df}{dy})+(\frac{ df*}{dz})(\frac{df}{dz})] - V(x,y,z)f*f[/tex] Determine the dynamic equation for this complex field. There are two ways to deal with complex fields: One is to treat the real and imaginary parts as two independent fields; the other, and much more useful, approach is to treat field f (x, t) and its complex conjugate field f (x, t) as the two independent fields. Comment on this dynamical system. 2. Relevant equations The euler-lagrange equation, presumably 3. The attempt at a solution It's very time-consuming to type out the obvious result of plugging into the euler-lagrange equation. Basically - should I be getting something resembling the Klein-Gordon equation? I'm getting two more or less identical dynamical equations; one for f and one for f* - should this be combined for f*f? |
| Dec28-07, 03:16 AM | #2 |
Nobody?
Ok, well, my main problem is that I can't see why the lagrangian is selected the way it is; the closest functional form I can derive is: [tex]L=\nabla(SS*) + \frac{d(SS*)}{dt} - V(x,y,z)SS*[/tex] This is obviously missing the correct coefficients. The question asks what the dynamical system represents - since I don't understand why this lagrangian was chosen and why the invariant is field x conjugate, I'm stumped. |
| Dec29-07, 02:10 PM | #3 |
Is this because nobody knows the answer, I haven't phrased the question properly, or I haven't done the work for it to be worth your time?
OK, I'll give you a little more working. I'm getting: [tex]\frac{1}{2} \nabla^{2}f* - \frac{i}{2}\frac{df*}{dt} - Vf* = 0[/tex] Does this look right? If so, what does it represent? I'm stumped. |
| Dec30-07, 05:20 PM | #4 |
Mentor
Complex field lagrangianAre you sure about all the factors of 2? |
| Dec31-07, 04:20 AM | #5 |
Positive - the approach we're taking in class - rightly or wrongly, it doesn't sound too rigorous - is to insert coefficients by hand afterwards.
It had occurred to me that it did look like the time-dependent schrodinger equation - but surely in order to derive that you'd have to use a spinor field, not a complex scalar, since that's what it operates on? I was under the impression that scalar fields in conjugate pairs were supposed to yield the klein-gordon equation, and that's the bulk of an example given later in our course. Actually, doing the derivation is ok, but the crux of the question is explaining the result, and that's what's baffling me. |
| Dec31-07, 06:08 AM | #6 |
Mentor
1) your Lagrangian didn't look close enough to the standard Lagrangian to give the Klein-Gordon equation 2) I didn't recognize your Lagrangian; 3) I was too Lazy to work out the equation of motion. |
| Dec31-07, 06:28 AM | #7 |
Many thanks for your help, I think I'm starting to get the hang of this now.
Are these standard sorts of questions to be asked? I get the impression that PF contributors are more familiar with lagrangians in the context of classical mechanics, whereas the faculty here seem to be of the opinion that it's useful only as a route to QFT and don't teach any as a classical mechanics class whatsoever. It isn't even offered on the BSc course and those graduates see no lagrangian or hamiltonian mechanics at all. |
| Dec31-07, 11:44 AM | #8 |
Mentor
I can't remember if I ever had to derives the non-relativistic Schrodinger equation from a Lagrangian, but I do remember seeing Lagrangian for the electromagnetic field, which leads to Maxwell's equations. I think that the idea behind the Schrodinger equation example is to show that a very familiar equation can be derived from an appropriate Lagrangian. Advanced courses classical mechanics give opportunities to introduce powerful, abstract theoretical techniques (Lagrangians, Hamiltonians, canonical transformations, Poisson brackects, Noether's theorem, Hamilton-Jacobi theory, etc.) in a somewhat familiar setting. All of these things were in a couple of classical mechanics courses that I had to take as an undergrad. Lagrangian stuff certainly is very, very useful in QFT and particles physics, but Lagrangian/Hamiltonian/variational stuff has uses all over the spectrum. For example, Brandon Carter was the first person to finds solutions to geodesic orbits around rotating black holes, and he did this by separating the Hamilton-Jacobi differential equation. Finally, a dissadent view from Roger Penrose (Road to Reality, page 491): "However, I must confess my unease with this as a fundamental approach. I have difficulties in formulating my unease, but it has something to do with the generality of the Lagrangian approach, so that little guidance may be provided towards finding the correct theories. Also the choice of Lagrangian is often not unique, and sometimes rather contrived - even to the extent of undisguised complication.There tends to be a remoteness from actual 'hands-on understanding, particularly in the case of Lagrangians for fields. ... Langrangians for fields are undoubtedly useful as mathematical devices, and they enable us to write down large numbers of suggestion for physical theories. But I remain uneasy about relying upon them too strongly in our searches for improved fundamental physical theories." |
| Jan3-08, 03:05 AM | #9 |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Complex field lagrangian
| Lagrangian density of the EM field | Classical Physics | 16 | ||
| the scalar field lagrangian | Quantum Physics | 2 | ||
| Why is the Electromagnetic Field Tensor in the QED Lagrangian? | Quantum Physics | 5 | ||
| Re: How to Field Theorize Starting from a Lagrangian | General Physics | 23 | ||
