Remove Blank Cells in Excel | Excel Problem Solution
  • Thread starter Thread starter pixel01
    Excel
The discussion revolves around a problem related to removing blank cells in an Excel column. Participants explore various methods to achieve this, focusing on practical solutions and user experiences.
  • Homework-related
  • One participant describes a method of selecting cells and using the "delete" function to remove blank cells, suggesting that users can choose how to shift remaining cells.
  • Another participant reiterates the same method but acknowledges the difficulty of selecting blank cells when they are numerous and randomly distributed.
  • A different approach is proposed, where users can utilize the 'Go To' feature to select 'Blank Cells' specifically, followed by deletion and shifting of remaining cells.
Participants generally agree on the methods to remove blank cells, but there is no consensus on the best approach, as different methods are suggested and discussed.
Some participants mention the challenge of selecting blank cells when they are scattered throughout a large dataset, indicating a potential limitation in the proposed methods.
This discussion may be useful for Excel users facing challenges with managing blank cells in their spreadsheets, particularly those looking for efficient methods to streamline their data.
pixel01
Hi all,
I have this excel problem: In a column, there are entries (can be characters or number), but there are also some blank cells. How could I remove all the blank cells so that the column is shorter.
Here I attached an illustration
Thanks for any comments
Technology news on Phys.org
Simple, select the cells to be removed. Use shift or control for multiple selections; go drop menu point "edit" and find function "delete". You will be prompted what to do with the remaining cells, to move up or left, etc.
Success
Success
Thanks Andre.
The thing is that in case there are hundreds of cells, to select blank cells is not simple.
Blank cells appear randomly.
To select just the blank cells, you can go to 'Edit', then 'Go To', click 'Special', and then select 'Blank Cells'. After that, delete them just like Andre said. You'll want to shift the remaining cells up, since you're removing blank cells in columns. Hope that helps.
Josh
Thank you Josh, it seems I have solved the problem.
Once again thanks Andre and Happy New Year to all of you
  • · Replies 18 ·
