Can Lightning Create a Sonic Boom?
  • Context: High School
  • Thread starter Thread starter Nymn
    Vibration
The discussion revolves around the nature of sound production, particularly in the context of collisions between metal objects and the phenomenon of thunder associated with lightning. Participants explore whether sound requires the vibration of the objects involved or if the air itself can generate sound through other means.
  • Exploratory, Conceptual clarification, Debate/contested
  • Some participants question whether sound can be produced without the vibration of the objects, suggesting that the air itself might vibrate to create sound.
  • Others propose that the collision of objects can push air and create sound waves, indicating that the objects do not necessarily need to vibrate.
  • A participant expresses uncertainty about the relationship between potential and kinetic energy in sound production, seeking clarification on the mechanics involved.
  • There is a comparison made between the sound of thunder and the sound produced by metal objects colliding, with a suggestion that the extreme heat from lightning creates sound through a mechanism similar to an explosion.
Participants express differing views on whether the vibration of objects is necessary for sound production, leading to an unresolved discussion regarding the mechanics of sound generation in various contexts.
Some assumptions about sound production and the conditions under which it occurs remain unaddressed, such as the role of the medium and the specifics of energy transfer during collisions.
Nymn
If two metal objects hit, do the objects have to vibrate to make a sound? Or can the air itself vibrate with the sound?
Is there was no air, could you hear the metal objects when they hit?
If the objects did not vibrate, what would cause the air to vibrate?
I don't know. I thought sound was the result of potential energy being released as kinetic energy (I don't know much about this, bear with my ignorance :| ). So one of the metal objects would have to vibrate for there to be sound?
The sound is a wave traveling in the air. When the objects hit they beame sourses of these waves. If there is a medium for these waves to travel (i.e. the air) they will reach at your ears and you will hear the sound.
The collision itself will push air, creating a sound like thunder or clapping hands. The objects themselves need not vibrate.
Oh, okay. That's what I was wondering. Someone told me that one of the objects would have to vibrate for there to be sound, but I figured the air alone would do it. A thought, is this how things like lightning make sound?
In a way. Thunder (the sound of lightning) is basically the aftermath of an explosion. A lightning bolt is in the millions of degrees, which superheats the surrounding air much as a high explosive such as C-4 would. That overpressure radiates in all directions from the path of the bolt, so the inverse square law applies to the intensity where it's heard.
  • · Replies 53 ·
9K
10K
  • · Replies 18 ·
  • · Replies 43 ·
