Logarithms and Exponents Question
The problem involves solving the equation 5^{x}=41, which falls under the subject area of logarithms and exponents. The original poster expresses difficulty in finding a solution, noting the challenge of not having a common base for both sides of the equation.
  • Exploratory, Assumption checking
  • Participants suggest taking logarithms of both sides as a potential approach. Some question the original poster's assumption that 5 cannot be raised to any power to equal 41, encouraging broader thinking beyond whole numbers.
There is an ongoing exchange of ideas, with some participants providing guidance on using logarithms. While the original poster acknowledges help, there is no explicit consensus on the final approach, and multiple interpretations of the problem are being explored.
The original poster indicates a sense of frustration with the problem, labeling it as simple yet difficult to resolve. This may reflect constraints in their understanding or approach to logarithmic functions.
aquamarine08
[SOLVED] Logarithms and Exponents Question
[tex]5^{x}[/tex]=41
The attempt at a solution
Well, I know that one way to figure this out would be that to find a common base for both sides of the equation and then use the known exponent to find the variable. The only thing with this is that there isn't any power that 5 could be taken to, to get 41. Please help...I know this is a simple question but I just can't get it.
Take log on both sides.
Sure there is. Don't limit your thinking to whole numbers.
More precisely;
find logarithm of both sides with either common logs or natural logs. Take your pick. Just use the same for both sides.
You then have your choice of using a table of logarithms or a good scientific calculator.
Process starts like this:
[tex]\[<br /> \begin{array}{l}<br /> \log (5)^x = \log (41) \\ <br /> x\log (5) = \log (41) \\ <br /> \end{array}<br /> \][/tex]
Can you take the process from there?
yep...i got it ! thanks everyone for ur help!
I like Stewartcs's solution better. Taking ln on both sides is a very easy way. This idea is thinking outside the box or he is thinking unlike the standard way. This deserves credit. Way to go, Stewartcs's!
