Special Rel. Creates pions decaying, most of question completed.
  • Thread starter Thread starter cpfoxhunt
    Pions
The discussion focuses on a relativistic anti-proton with a total energy of 30 GeV colliding with a proton in the Earth's atmosphere. The journey duration in the anti-proton's rest frame is calculated to be approximately 738 years due to its high velocity, with a Lorentz factor (gamma) of about 31.98. The available energy for particle production from the collision is determined to be 7.6 GeV, leading to the generation of approximately 56 pions. The decay time for these pions is estimated at 5.19 x 10-3 seconds in their rest frame, with considerations for their velocity necessary to finalize the calculations.
  • Understanding of special relativity concepts, including Lorentz transformations.
  • Familiarity with particle physics, specifically energy-mass equivalence and particle decay.
  • Knowledge of invariant mass and energy-momentum relations.
  • Basic calculations involving relativistic speeds and proper time.
  • Study the Lorentz transformation equations in detail.
  • Learn about invariant mass and its applications in particle collisions.
  • Explore the properties and decay mechanisms of pions in particle physics.
  • Investigate the implications of relativistic speeds on time dilation and length contraction.
Students and professionals in physics, particularly those focusing on particle physics and relativistic mechanics, will benefit from this discussion. It is also relevant for educators preparing coursework on special relativity and particle interactions.
cpfoxhunt
I was wondering if I am getting anything like the right answers here to this:
12. A relativistic anti-proton, with total energy 30 GeV, travels 2.5 x i04 light years (2.36 x 1020 m) from the centre of the Milky Way galaxy and collides with a proton in the Earth's atmosphere How long does the journey take in the rest frame of the anti-proton? [3]
How much energy is available for the production of new particles from this collision? [8]
Assuming that all of this available energy is used in the production of pions in a single event, how many pions would be generated? The pions travel vertically downwards through the Earth's atmosphere. A counter in a laboratory on the Earth's
surface records 7 pions from the collision event. Estimate the height above the laboratory at which the collision occurred. [9]
[The rest mass of a pion is 135MeV/c2, and that of a proton is 938MeV/c2. The mean
proper lifetime of the pion is 2.5 x 10-6 s.
Invarience of the interval, e^2 - p^2 = m^2
OK, first I use the fact that E = MGamma to work out that gamma is about 31.98, and beta is about 0.99 so the thing is traveling at near as can tell c ( well 0.999c, nothing that makes any difference). In the rest frame of te anti proton it won't take nearly so long because the galazy is moving pretty quickly past it, so t = 2.5E4/31.98 = 738 years
Now for the energy: I have a particle with the energy of the rest mass of the proton (I assume the one in the Earth isn't doing much), and a particle with 30Gev. M = mass proton, assume particle physics units. E1 = 30Gev
Using invarience, (E1 + M)^2 -P1^2 = Etotal squared
Using the fact that E1^2 - p1^2 = M^2
2E1M + 2M^2 = E total squared
So E total available = 7.6 Gev
This can make abot 56.4 pions (so call it 56 pions)
This is where I start having problems: For that 56 pions to decay to 7 pions, i can work out how much time has passed (mean lifetime * ln2 = half life, 3 half lives have passed so about 5.19E-3 seconds).
How do I work out how fast the pions are going to finish the question? If I assume they are going at c I get a fairly sensible answer, but why would I be able to assume that?
Cheers
Cpfoxhunt
Remember that this time (5.19E-3) is the time that elapses in the pions rest frame, not the Earth's rest frame. In the Earths rest frame elapsed time will be longer.
I don't think you can just assume the pions move at c.
What you do know is the Total Kinetic of all the pions T = (Original Energy - 7.6 Gev). Since we're assuming all available energy went to producing the pions, the pions must all move at the same velocity. So each pion has the same KE (T / #pions). Then you can find their velocity
