Bose-Einstein Condensation in 2d?
The discussion revolves around the possibility of achieving Bose-Einstein condensation (BEC) in two-dimensional (2D) systems. Participants explore theoretical frameworks, mathematical reasoning, and physical explanations related to this phenomenon, including implications of various theorems and models.
  • Some participants express skepticism about the occurrence of BEC in 2D systems, suggesting that mathematical and physical reasons need to be explored further.
  • Reference is made to the Mermin-Wagner theorem, which indicates that long-range order, such as BEC, cannot exist in 2D systems due to fluctuations.
  • Others propose that BEC can occur in 2D under specific conditions, such as when the energy of boson particles is proportional to momentum.
  • Mathematical arguments are presented regarding the density of states and its implications for the existence of BEC in 2D, highlighting the divergence of integrals that affect temperature conditions for condensation.
  • Some participants mention that in finite 2D systems, certain signatures of BEC can be observed, despite the theoretical challenges posed by infinite systems.
  • Discussion includes the Kosterlitz-Thouless transition, which describes a phase with quasi-long-range order in 2D systems, and how this relates to the superfluid phase.
  • Physical explanations are offered regarding the role of long-wavelength phonons in destroying coherence in infinite systems, and how finite size effects might alter this behavior.
Participants do not reach a consensus on whether BEC can occur in 2D systems. Multiple competing views are presented, with some arguing against it based on theoretical grounds, while others suggest conditions under which it might be possible.
Limitations in the discussion include the dependence on specific potentials, the implications of finite versus infinite systems, and the unresolved nature of mathematical steps related to the density of states and temperature conditions for BEC.
T-7
I'm wondering -- would you get the phenom. of Bose-Einstein condensation in a 2D system. My intuition is "no", but I'm having a hard time saying why. I suppose I could try and work it out mathematically (no time, right now) -- perhaps someone has? -- but a physical explanation would be nice too.
Thanks in advance for your insights.
Look up the Mermin Wagner theorem. Then, if you feel like going further, look up the Kosterlitz-Thouless (1973) paper.
One can get BEC in 2D if energy of bozon particle is proportional to momentum:
E=const*p
See for example pairion condensation in 2D in the book:
Quantum Statistical Theory of Superconductivity
by Shigeji Fujita and Salvador Godoy
Kluwer Academic Publishers
http://www.ebooks.kluweronline.com
It depends on the kind of potential the particles are in. I don't have a good physical reason handy for why you shouldn't normally get BEC in 2d, but here's a mathematical reason for a given case. For free particles,
[tex]E = \frac{\hbar^2}{2m}\left(\frac{\pi}{L}\right)^2n^2[/tex],
where [tex]n^2 = n_x^2 + n_y^2[/tex]
and [itex]k_x = \pi n_x/L[/tex].<br /> <br /> If you compute the density of states, you find [tex]g(E) = \frac{L^2m}{2\pi\hbar^2}[/tex].<br /> <br /> The number of particles in the system is then approximately equal to (this doesn't really count particles in the ground state)<br /> <br /> [tex]N \approx \frac{L^2mk_BT}{2\pi\hbar^2}\int_0^{\infty}\frac{dx}{e^x-1}[/tex]<br /> <br /> If you suppose we fix N, then the temperature is given by<br /> <br /> [tex]T \approx \left[\frac{L^2mk_B}{2\pi N\hbar^2}\int_0^{\infty}\frac{dx}{e^x-1}\right]^{-1}[/tex]<br /> <br /> But the integral there diverges, and so the temperature tends to zero - i.e., you a temperature of zero for BEC to occur in this 2d system.<br /> <br /> Really, the crux of the matter is the density of states. You need a density of states such that the Bose integral will not diverge. The constant g(E) in this example was the first sign of danger. The density of states needs to be a higher power of E in order for that integral to converge. This determines what kind of potentials might results in a BEC in 2d.[/itex]
The cause of BE condensation is a filling of all excited states. Once these states are filled, the ground state is the only place for particles to go, so all additional particles will condense in the ground state.
The equation for N in the previous post is actually the number of particles in an excited state. When this integral is taken, you find N excited, which ends up having no limit.
Nex = AmkbT/(2*pi*hbar2)*(-ln(1-z)*kbT
Because there is no limit to Nex, you can add more and more particles, and they will go into an excited or ground state, rather than only a ground state.
This is only true for infinite 2D systems. For some finite 2D systems you can see several "smoking guns" of a BEC like long-range off-diagonal order, spontaneous build-up of coherence, quantized vortices and half-vortices and a linearized Bogoliubov excitation spectrum. Although this looks a bit like cheating - a true BEC is considered to be an infinite system - truly infinite systems are of course never realized experimentally.
See for example the famous paper by Kasprzak et al. for an example of a 2D BEC: http://www.nature.com/nature/journal/v443/n7110/abs/nature05131.html (J. Kasprzak et al., Bose–Einstein condensation of exciton polaritons, Nature 443, 409-414 (2006)).
If you want the hard theoretical analysis, Gokul43201 already pointed you to the important papers.
I consider the definitive textbook on these things to be Quantum Liquids by Leggett. He deals with the realities of experiment very carefully from the theoretical side.
As has been alluded to, there is some argument as to what BEC is in realistic systems of finite sizes, trapping potentials and finite lifetimes.
The simple answers have been given above:
1. Mermin-Wagner says that for free particles you can't get a proper BEC.
2. You can if you assert an appropriate trap, e.g. harmonic.
3. Condensates in 2D go through a Kosterlitz-Thouless transition. This is because in 2D it is entropically favourable to create dipole pairs of vortices, which mess up long range order and give an algebraic decay ("almost" short range). At high T, these unbind and exponentially decaying order is restored.
4. Leggett prefers to use a different definition of condensation; using this, free 2D systems have no difficulty condensing, simply displays different phenomenology.
For a physical explanation, you could consider long wavelength phonons destroying the coherence in an infinite system. However, in a real system, finite size effects give a lower bound on the phonon energy and so it requires more energy for a phonon to show up and start tearing the condensate apart...
Mermin-Wagner theorem tells you that if there is a long-range-order (existence of BEC) in two-dimensional systems, the fluctuations will drive the system to somewhere else, destroying the condensate. Yes, as puzzly said, it is the long-wavelength phonon that destroys the coherence of the infinite system.
Another way to view it is that the atoms have fewer freedom to move in two-dimensional space than three-dimensional space. The effectively stronger interaction between atoms make the long-range correlation impossible.
For Kosterlitz-Thouless transition, it is about the existence of another phase at low-temperature with quasi-long-range order, despite the absence of true long-range-order. In 2D Bose gas, it is the superfluid phase.
But since bosonic systems are all prepared in a trap, the finite-size effects play a big role. I suggest reading the experimental report PRL 102, 170401 (2009)
