How Do You Calculate the Amplitude for a Mass to Fall Off in SHM?
  • Thread starter Thread starter salman213
    Amplitude Shm
The discussion revolves around a problem involving a spring connected to a mass on a frictionless surface, with a smaller mass placed on top. The goal is to determine the amplitude at which the smaller mass will fall off, given a coefficient of friction and spring constant.
  • Mixed
  • Participants explore the relationship between the forces acting on the masses and the spring's properties, questioning how to equate frictional force with spring force to find the amplitude.
  • Some participants discuss different methods for calculating the amplitude, leading to varying results and confusion regarding the correct approach.
  • Questions arise about the definitions of angular frequency and how they impact the calculations, particularly in relation to the mass of the system.
There is ongoing exploration of different methods, with some participants expressing confusion over discrepancies in results. Guidance has been offered regarding the correct application of formulas, but no consensus has been reached on which method is definitively correct.
Participants note that the problem involves specific values for mass and spring constant, and there is mention of a professor's solution that differs from the original poster's calculations. The discussion highlights the importance of correctly accounting for all masses in the system.
salman213
1. There is a spring connected to a mass on a frictionless horizontal surface. Another mass smaller in size is placed ontop of the bigger mass. It asks find the amplitude so that the smaller mass falls off. Coeffient of friction is 0.4 between the two masses. K is given as 200 N/m
2. Simple harmonic motion eqn's
3. F = kx
friction force between the smaller mass and bigger mass is = mu * Normal
Normal = smaller mass times 9.81 m/s^2
so i got my frictional force...
is that equal to Kx where K is given so i solve for x?
The maximum force will occur at the max amplitude of the oscillation so you need to set that equal to the force required to make the block move as you have stated above.
is this right
the mass of each blocks are given m = 1.8 kg and M = 10 kg where m is smaller and M is the bigger mass
the force required to make the small block move:
normal of the small mass = 1.8 x 9.81 = 17.66 N
Force required to move small mass = 0.4 x 17.66 = 7.064N
Now is this the force we are looking to create through the spring
Im guessing YES
F= kx
F = friction force
therefore
7.064 = (200)Xm
Xm = 0.0353 m
Look ok to me.
ok THANKS A LOT BUT...can u check this
SOMEONE ELSES SOLUTION, IM CONFUSED WHY THEY ADD THE MASSES ETC..THEY GET DIFF ANSWER
and supposedly its the right answer but I am not sure why..
fmax = μs*mg <<agreed assuming m is equal to the smaller mass
am =ω^2Xm <<agreed since this is just a formula...
ω=sqrt of k/ (m+M) is the angular frequency <<<< now here is the difference i guess they add m+M i think as a result the answer i got and this answer varies. But which one is right and why!
m*am = μ*mg =>
k
---*Xm = μ*g
m+M
Xm = 0.22 m
I got Xm = 0.0353 m as u can see from my previous post...
any help?
http://img159.imageshack.us/img159/9457/35240720td4.jpg
Omega is the angular frequency and is: [itex]\omega = 2\pi f[/itex] If i recall correctly.
Both methods are fine. If you divide the answer your friend gets by [itex]2\pi[/itex] the answer will be the same as yours. The beauty with yours is it needs less fiddling about.
O but how my distance is different :O
so different amplitudes will still give u the same force by the spring?
how does Dividing or Multiplying by [itex]2\pi[/itex] give u the same answer...like with angles i know if u add [itex]2\pi[/itex] it is the same angle when using sin or cos or tan but how come you can multiply the value of an amplitude by [itex]2\pi[/itex]
like how will an amplitude of 0.03 or 0.2 BOTH result in the smaller mass falling off....? i thought there would be a unique solution
There is a unique solution. The flaw with the second method you put up is that omega is incorrectly defined. It is missing a factor of [itex]2\pi[/itex]. When you use the correct definition you obtain the same answer as in the first method. Try method 2 again with:
[tex]\omega = 2\pi \sqrt{\frac{k}{m}}[/tex]
are u 100% sure
cause in my course notes this is what i have....
F= ma = -m(ω^2*Xm) = -(m*ω^2)*Xm = -kx
k = mω^2
ω= [tex]\sqrt{\frac{k}{m}}[/tex]
no [tex]2\pi[/tex]
No you are correct I'm talking rubbish. I don't know where I got that from. If you give me a few minutes I'll go over it properly since I was trying to do too many things at the same time.
ok thank you so muchhhhhh i will be waiting i have been stuck why mine or perhaps his is wrong for awhile now :(
First of all sorry I've turned this into a total mess. Now what is wrong with the second method is that you have calculated the acceleration for the two masses on the spring then when you calculate the force you assume only the mass of the small block. What it needs to be is the mass of the two. So:
[tex]F = (M+m)A\omega^2 = \mu m g[/tex]
and that will be consistent with the first method.
ok i think i shoudl have said this before the second method is the prof's solution...and he said its from the sol'n manual but so its wrongg:S?
by the way thanks a lot for taking time to look at this question for me!
F= kx
F = friction force
therefore
7.064 = (200)Xm
Xm = 0.0353 m
is right?
I hate to have to do this and feel so awful since its entirely my fault (I've been having a bad day). The book is correct and your method must be wrong but I can't see how yet. The derivation you used in post 5 is fine.
I've been utterly useless in a most embarrassing way and for that I apologise.
hmm ok
  • · Replies 18 ·
