Rotation Mechanics [disk-axle mechanism]
The problem involves a disc rotating with a constant angular velocity and a rod connected to a ring that moves vertically. The scenario is set up to determine the angular velocity of the disc based on the motion of the rod and the ring at a specific angle.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the relationship between the motion of point A on the disc and the vertical movement of the ring. There are attempts to apply differential calculus to relate the components of the rod's length to the velocities involved. Questions arise regarding the assumptions about the fixed points and the geometry of the setup.
The discussion is active with various interpretations being explored. Some participants have provided guidance on how to approach the problem using the constant length of the rod, while others are clarifying the relationships between the components of motion. There is no explicit consensus yet, but several productive lines of reasoning have been established.
Participants are working under the constraints of a fixed rod length and the geometry of the rotating system. There is an emphasis on understanding the implications of the angle and the distances involved in the setup.
rohanprabhu
[SOLVED] Rotation Mechanics [disk-axle mechanism]
Q. A disc is fixed at its center O and rotating with constant angular velocity [itex]\omega[/itex]. There is a rod whose one end is connected at A on the disc and the other end is connected with a ring which can freely move along the fixed vertical smooth rod. At an instant when the rod is making an angle 30º with the vertical the ring is found to have a velocity [itex]v[/itex] in the upward direction. Find [itex]\omega[/itex] of the disk. Given that the point A is R/2 distance vertically above the point O and length of the rod AB is l.
http://img175.imageshack.us/img175/4992/rotadiscaxlecl9.jpg
I don't know.. maybe:
[tex]v = r\omega[/tex]
[tex]\tau = I^2\alpha[/tex]
The point 'A' moves in the inner circle of radius 'R/2'. I tried marking two positions in the inner rim, at 'A' and 'a' where the angle made by the axle with the vertical rod is [itex]\theta[/itex] and [itex]\theta + d\theta[/itex]. The angle at the cross section of the two impressions of the rod comes out to be [itex]d\theta[/itex].
http://img88.imageshack.us/img88/7963/rotadiscaxleattit6.jpg
I somehow need to equate it with the angular displacement for the disk. The key idea here, however is that the length of the rod will remain constant. I'm just not able to understand as to how i go about using that...
also.. i think that if i can somehow prove that this is the case of rotation about a fixed point on the rod, then things will become much easier. how do i go about doing this?
any help is greatly appreciated. thanks...
Whether the disc and the vertical rod are in the same plane? Whether the point A on the rod is firmly fixed or pivot around A?
Point 'A' is exactly above the center of the circle when the axle makes 30º with the vertical rod. At other times, it is a point on a concentric circle on the disc of radius R/2.
And yes, they are in the same plane...
Take advantage of the fact that the length of the rod doesn't change. View its length as having vertical and horizontal components (Y & X, say). At the moment in question, the horizontal component is increasing at the rate of [itex]\omega R[/itex] (since end A is moving horizontally), so at what rate must the vertical component decrease to keep the length constant? (Think in terms of differentials.)
ok.. so here's what I've assumed. Have a look at the figure:
http://img265.imageshack.us/img265/1679/solutiononeen5.jpg
I've dropped a perpendicular on the vertical rod from the point 'A' at 'B'. I've taken the distance of this horizontal as 'y'. Also, the distance from the point of contact of the rod and the axle and 'B' is taken as 'x'.
So, we have:
[tex] x^2 + y^2 = l^2[/tex]
diff. both sides w.r.t. time:
[tex] 2x\frac{dx}{dt} + 2y\frac{dy}{dt} = 0[/tex]
Now, here [itex]\frac{dx}{dt} = v[/itex] and [itex]\frac{dy}{dt} = \frac{R\omega}{2}[/itex]
on substituting these values, i get:
[tex] v = -\frac{y}{x} \frac{R\omega}{2}[/tex]
here, [itex]\frac{y}{x} = tan(\frac{\pi}{6}) = \frac{1}{\sqrt{3}}[/itex]
So,
[tex] \omega = -\frac{2\sqrt{3}v}{R}[/tex]
is it right??
I have an option like that.. but they're all positive... what does my negative sign indicate? Although it does indicates the direction of axis of rotation.. but ofcourse it has to be relative to the assumptions i have taken for sign convention. So, relative to what exactly is the positive sign...
rohanprabhu said:
So, we have:
Looks good.
Why did you divide by 2? [Correction: Looks good!]
So,
is it right??
Except for that factor of 2. [Correction: Looks good!]
The vertical component of the rod length (your X value) decreases (thus is negative) at the same rate that end B rises (and is thus positive).
Edit: I was taking R as the distance from point A to the axis, but that distance is R/2 not R. Thanks to Shooting star for pointing out my error.
The rotating point where one end of the rod is fixed is at a dist of R/2 from the centre.
D'oh! My bad. (I'll correct my error in the previous post. Thanks, Ss!)
k. I get it now.
thanks a lot to everybody who helped me out. Doc Al, shooting star.. u guys r gr8 :D
thanks again..
  • · Replies 25 ·
  • · Replies 31 ·
