Equation of the plane EQUIDISTANT from two points
The discussion revolves around finding the equation of a plane that is equidistant from two given points in three-dimensional space: (2, -1, 1) and (3, 1, 5). Participants are exploring the geometric properties of the plane and its relationship to the points provided.
  • Participants discuss the relevance of the midpoint between the two points and its role in determining the plane's equation. There is also consideration of direction ratios and the normal vector to the plane. Some express confusion regarding the initial steps and the relationship between the midpoint and the plane.
The discussion is active, with participants sharing their thoughts on how to approach the problem. Some guidance has been offered regarding the significance of the midpoint and the direction ratios, but there is still some uncertainty about the initial steps and interpretations.
Participants are navigating the concepts of geometric relationships and vector equations in the context of the problem, indicating a need for clarity on definitions and assumptions related to the plane and the points involved.
ko_kidd
I got two points that are
and I need to find the equation of the plane equidistant from those points.
Anyone?
Since it's equidistant, finding the midpoint should allow you to calculate the direction ratios of the normal to the plane. Once you find that, you should be able to obtain the equation to the plane. ie, [tex](\vec{r} - \vec{a}) . \hat{n} = 0[/itex][/tex]
Midpoint between what though? Midpoint between the points maybe?
I'm confused. I was thinking the first thing was to create a vector parallel to the lines or vector equation of the line based on the two points (if I did that part correctly)
what I got was
<x,y,z> = <2,-1,1> + t<1,2,4> = <z+t,-1+2t,1+4t>
what I got was
Yes, and that gives you the direction ratios of the normal to the plane.
Yeah. Since it's equidistant, this midpoint lies on the required plane. Now that you've got a point lying on the plane, and the direction ratios of the normal to the plane, you should be able to find the equation of the plane.
The plane equidistant from two points contains the midpoint of the line segment between them, and is perpendicular to that line. That's all you need.
  • · Replies 20 ·
11K
