How do you remove water droplets inside watch?
  • Thread starter Thread starter chrisalviola
    watch Water
The discussion revolves around methods to remove water droplets from inside a watch after it has been exposed to moisture. Participants share various techniques and suggestions, including both DIY approaches and professional assistance, while considering the potential risks and effectiveness of each method.
  • Practical advice
  • Some participants suggest removing the back cover of the watch to allow it to dry out, while others express difficulty in opening it.
  • There are recommendations to take the watch to a jeweler or watchmaker, especially if it is valuable.
  • One participant proposes using silica gel desiccant packages in a sealed bag to absorb moisture.
  • Another suggestion involves placing the watch in a warm oven for a few hours, with caution regarding temperature accuracy.
  • Some participants humorously discuss extreme methods, such as using a torch, while acknowledging the risks involved.
  • A participant mentions using a moisture extraction container designed for hearing aids as a potential solution.
  • There are concerns about irreversible damage to the watch's workings if moisture remains for too long.
  • One participant humorously suggests submerging the watch in water to mask the droplets, which is not a practical solution.
Participants do not reach a consensus on the best method to remove moisture from the watch. Multiple competing views and techniques are presented, with some advocating for professional help while others suggest DIY methods.
Participants express uncertainty about the effectiveness and safety of various methods, and there are warnings about potential damage to the watch if not handled carefully. The discussion includes a mix of serious advice and humorous exchanges.
Individuals seeking solutions for moisture issues in watches, watch enthusiasts, and those considering DIY repairs or professional services.
chrisalviola
I forgot to take my watch inside my clothes pocket and when I washed my clothes my watch formed some moisture and small water droplets inside, I let it dry under the sun for3-4 hours every day but still there's moisture inside, it seems won't go away. what do you recommend I should do?
I'd first try just popping the back off (where the battery is located) and let it sit for a few days to dry with the cover off so the moisture can get back out, i.e., don't wear it while trying to get it to dry.
thats the problem there I can't open the back plate.
If its an expensive watch I'd take it to a local jeweler or watch maker and see what they recommend.
If the watch is valuable, take it to a jeweler. If it's not, even the jewelry counter at a discount store can pop it open.
Edit: Great minds think alike.
ok will try to bring this to a local jeweler tnks, I was hoping there's a technique for these meybe in an oven or a dehydrator maybe.
The damage to the workings may be irreversible at this point and drying alone won't help.
If its a fairly inexpensive metal watch case, use a knife to pop the back of the bezel off. Just use the blade at the little rectangular spot on the back of the bezel. Its just like using a jewelers wrench.
Here's a photographer's trick: Find as many of those silica gel dessicant packages ("do not eat! Throw away!") as you can, and seal them up with the watch in a zip-lock bag and leave them in a warm place. As has been said, damage may already be done.
thats a good idea tnks.
If the drops are bothering you just put the watch in a glass of water until it is completely full of water and you won't notice the drops
:smile: When I saw your name replying to this, I was expecting the advice to be to heat the watch with a MAPP torch to evaporate out all the water. :wink:
I thought about that, but when I tried it on my watch I burned the heck out of my wrist
I'm dead. DoL. I've died. I'm dead.:snarf: Rofl::eek:
You are supposed to put the watch on your living-room carpet when you use a torch to dry it.
And then flip the square of carpet to cover the damage?
I see you've been following closely!
Go somewhere where they sell hearing aids and ask for the little container thing that extracts moisture out of small thing (like hearing aids). Buy one for like $10. If you put it in there every night, you'll never see droplets of water in your watch.
Putting a watch in a 120F or even 150F oven for a few hours should dry it out without causing any damage. Be careful, though, and use a thermometer -- many household ovens do not properly indicate temperatures this low.
- Warren
Stick it in a desiccator filled with Dryrite. Wait until the dryrite turns pink. It will definitely work.
Remove the back cover and let it dry out. Replace the back cover when it is dry. You may need to clean the crystal if there are water spots after it is dry. There is also water in the interior of the watch which can cause real problems unless you really dry it out. Removing the cover is the fastest and surest way.
And then use your phone to post on PF how great it worked.
I will need to boost reception of the wi-fi signal. How can this be done?
My brother owns a clock/watch repair store. He said what Evo said about taking it to a jeweler. If it were his watch he would open the back(it will either screw off or pry off) and blow it with a hair dryer. He also says it would be best to remove the watch from the case but "BE VERY CAREFUL NOT TO BREAK THE STEM, SCRATCH THE COIL OR CIRCUIT."
9K
  • · Replies 28 ·
  • · Replies 23 ·
  • · Replies 19 ·
13K
9K
