How Do You Solve These Kinematics Problems Involving Falling Objects?
  • Thread starter Thread starter Phantom8295
    Couple Kinematics
The discussion revolves around kinematics problems involving falling objects, specifically a rock dropped from a cliff and an apple dropped with photographic intervals. The original poster seeks assistance in determining the height of the cliff and the timing of the camera flashes for the falling apple.
  • Participants explore the relationship between the time taken for the rock to fall and the time for sound to travel back up. There are discussions on the equations of motion and the implications of the apple's size on the timing of the camera flashes.
Some participants have provided insights into the equations involved in the rock problem, while others express uncertainty regarding the apple problem. There is a mix of interpretations about the requirements of the apple's photographic timing, with some suggesting the need for clarity on the problem's wording.
Participants note the importance of understanding the time intervals involved in both problems and question the assumptions made about the camera's operation and the apple's dimensions. There is also mention of previous discussions that may provide additional context for the cliff problem.
Phantom8295
Can anyone suggest how to do these problems.
1) A rocks is dropped from a sea cliff and the sound of it striking the ocean is heard 3.4s later. If the speed of sound is 340m/s, how high is the cliff?
2) An apple is dropped and a multi-flash camera is used to take photographs of the falling apple. If the apple is of 10c in diameter, estimate the time between each photoflash of the apple?
I got really stuck with these two problems. Any suggestions how to solve them?
Thanks
P.
Over on page 3 is a similar question entitled "Simple Problem: Depth of Well providing sound reaches you in 1.5 seconds" and Doc Al (one of the bigger of the Brains on PF) said how to do it, something about quadratics. Maybe you'll get lucky and he'll answer it again...
That second problem, I don't know at all. Guess you'll need to find its volume (it's sort of a sphere) and think of it falling down at the gravitational constant. Guess they want to have a clear shot of it each time?
Good luck, hope one of the Brains answers you.
Let H be the height of the cliff. The function describing the rock's location is:
[tex]y_{(t)} = \frac{1}{2}gt^2[/tex]
From there you can find the time it takes the rock to reach the bottom of the cliff:
[tex]y_{(t = t_f)} = \frac{1}{2}gt_f^2 = H[/tex]
[tex]t_f = \sqrt{\frac{2H}{g}}[/tex]
Now, how much time does it take sound to travel a distance of H (from the bottom of the cliff to your ears) at a speed of 340m/s?
[tex]H = v_st_s[/tex]
[tex]t_s = \frac{H}{v_s}[/tex]
Finally, you know that the sum of these two time intervals should equal 3.4 seconds:
[tex]t_f + t_s = 3.4[/tex]
[tex]\sqrt{\frac{2H}{g}} + \frac{H}{v_s} = 3.4[/tex]
If you let [tex]x = \sqrt{H}[/tex] you get this equation:
[tex]\frac{x^2}{v_s} + x\sqrt{\frac{2}{g}} - 3.4 = 0[/tex]
Now solve for x and then find H. :smile: I get H = 51.7 meters.
thanks chen
I solved that problem.
As for the apple problem, its basically an apple is dropped and the photos are taken at regular intervals. The shot does not have to be a complete apple, as it falls down the acceleration increases and the distance between the previous position to current position increases at each shot. The questions is how many shots can be taken in a sec, or what's the time interval between each shot. Hope i am making it clear. I am still clueless about it. Have to try it again tomorrow. Have a good night folks.
P.
That really depends on what kind of camera you're using, doesn't it?
You could program the camera to take pictures such that the distance between each image of the apple is the same, or you could take the pictures at a constant rate to see the acceleration.
What exactly is being asked?
cookiemonster
They must want a clear shot of the apple each time. That's why they give a hint on its size. Since it's going to fall approx 5 m during the second, how many lengths of apple is that? That may be what they want.
They want him to find the distance between r(0s) and r(1s)? Seems kinda easy...
cookiemonster
:eek: E A S Y ? ? ? :eek:
Easy for whom? Yeah, for someone with a big ol' brain, maybe...
Edit: Well I see Chen did your homework for you, so you don't need my help below. But you didn't learn anything either; nice work Chen! :wink:
The time interval from when the rock is dropped to when the sound is heard can be divided into two parts (t1 and t2) that add to give 3.4secs. What does each part mean? Can you find an equation for each one? Is there a variable that represents the height of the cliff in each one?
Check the original wording of the problem; you're leaving something out.
I have great confidence in phantom that he could solve such a problem. =]
cookiemonster
