Help with Volume...circular disk.
by quickclick330
Tags: disk, volumecircular
quickclick330
quickclick330 is offline
#1
Jan22-08, 08:03 PM
P: 87
Consider the solid S described below.
The base of S is a circular disk with radius 3r. Parallel cross-sections perpendicular to the base are squares.
Find the volume V of this solid.
I tried this....
A(x) = pi*r^2 = pi*(3r)^2 = pi*9r^2
V(x) = integral from 0 to 3r(pi*9r^2 dx) = pi*27r^3
Am I approaching this problem the wrong way? Thanks for the help!
Phys.Org News Partner Science news on Phys.org
Simplicity is key to co-operative robots
Chemical vapor deposition used to grow atomic layer materials on top of each other
Earliest ancestor of land herbivores discovered
dynamicsolo
dynamicsolo is offline
#2
Jan22-08, 10:53 PM
HW Helper
P: 1,664
Quote Quote by quickclick330 View Post
The square cross-sections are built upon the circular base, so each cross-section has a side length given by the length of a chord of the circle; these "slices" are standing upright on the circle. (Making a picture of this will be helpful to you.) The solid is symmetric about a diameter of the circle, so you can integrate half the solid and multiply your result by two.
So what you need is to find the length of a chord of the circle which has its midpoint at a distance x from the circle's center. That length gives you the area A(x) of each cross-section. You would then integrate A(x) from x = 0 to x = 3r and multiply the resulting volume by 2.
Register to reply
Related Discussions
Hieght of a volume in a cylinder on its side, with known volume. Precalculus Mathematics Homework 2
circular disk rotates with student on it Introductory Physics Homework 4
Volume of Right Circular Cylinder Calculus & Beyond Homework 3
volume expansion problem...wheres initial volume? Introductory Physics Homework 2
Disk speed NON UNIFORM and UNIFOR CIRCULAR MOTION Introductory Physics Homework 3
