Change of variables for multiple integrals (3)
The problem involves evaluating a double integral over a specific region in the first quadrant defined by the curves xy=1, xy=3, x² - y² = 1, and x² - y² = 4. The integral to compute is ∫∫(x² + y²)dA, with a hint suggesting a change of variables using G(x,y)=(xy, x² - y²) and the Jacobian determinant.
  • Participants discuss the application of the change of variables theorem and the role of the Jacobian determinant in transforming the integral. Questions arise regarding the manipulation of the Jacobian and its integration limits, as well as the reasoning behind the disappearance of the Jacobian in certain steps.
Some participants express confusion about the steps taken in the solution, particularly regarding the use of the Jacobian and the limits of integration. Others attempt to clarify the reasoning behind the transformations and the relationship between the original and transformed integrals, indicating a productive exploration of the concepts involved.
There is an emphasis on understanding the implications of the change of variables and the Jacobian in the context of the given integral, with participants questioning the assumptions made in the solution process.
kingwinner
Q1: Let S be the region in the first quadrant bounded by the curves xy=1, xy=3, x2 - y2 = 1, and x2 - y2 = 4. Compute
∫∫(x2 + y2)dA.
S
(Hint: Let G(x,y)=(xy, x2 - y2). What is |det DG|?)
Solution:
http://www.geocities.com/asdfasdf23135/advcal19.JPG
I don't understand the third and fourth equalities in the solutions. Can someone kindly explain?
If you don't understand why
[tex]\int\int_S(x^2+ y^2)dA= \frac{1}{2}\int\int_S |det DG| dA[/tex]
then you have missed the whole point of this section! |det DG| is the "Jacobian" and |det DG| dA is the differential in terms of the new variables u= xy, v= x2- y2.
[tex]det DG= \left[\begin{array}{cc}\frac{\partial xy}{\partial x} & \frac{\partial x^2- y^2}{\partial x} \\ \frac{\partial xy}{\partial y} & \frac{\partial x^2- y^2}{\partial y}\end{array}\right]= \left[\begin{array}{cc}y & 2x \\ x & -2y\end{array}\right]= -2(x^2+ y^2)[/itex]<br /> as they say so |det dG|= 2(x<sup>2</sup>+ y<sup>2</sup>). You already have x<sup>2</sup>+ y<sup>2</sup> in the integral so you only need to multiply inside the integral by 2 and multiply outside the integral by 1/2 to get [itex]1/2 \int\int |det dG|dA[/itex].<br /> <br /> Now, for the limits of integration. Your region is bounded by xy= 1, xy= 3, x<sup>2</sup>- y<sup>2</sup>= 1 and x<sup>2</sup>- y<sup>2</sup>= 4. That, of course, was the reason for the choice of G. With u= xy, u= xy= 1 and u= xy= 3 are the u limits of integration. With v= x<sup>2</sup>- y<sup>2</sup>, v= x<sup>2</sup>- y<sup>2</sup>= 1 and v= x<sup>2</sup>- y<sup>2</sup>= 4 are the v limits of integration.[/tex]
Change of variables theorem says
∫∫f(x,y)dA
S
=∫∫f(G(u))|det DG| dudv ?
G-1(S)
So you should add the Jaconbian factor, but why are they moving it away? (it seems that they are doing it the oppposite way than the theorem states)
For the fourth equality, I don't understand why |det DG| disappeared.
You are going in the wrong direction.
Suppose you had the problem [itex]\int x dx[/itex] (yes, I know that's trivial!) and you decide to make the substitution u= x2 (yes, I know that's a peculiar choice!). Then du= 2x dx so (1/2)du= xdx. Since you already have "xdx" in the integral, in terms of u, you have just [itex](1/2)\int du= (1/2)u+ C= (1/2)x^2+ C[/itex]. The "x" inside the integral was "absorbed" into the du.
  • · Replies 16 ·
  • · Replies 16 ·
