Thread Closed
density of SiO2
Share Thread Thread Tools
Jan25-08, 05:18 PM   #1
density of SiO2
in the periodic table we have the density of each element ( density(Si) = 2.33), density(O)=1.429). i wonder how we could calculate the density of SiO2 ???
PhysOrg.com
PhysOrg
physics news on PhysOrg.com
>> Promising doped zirconia
>> Nanocrystals grow from liquid interface
>> New insights into how materials transfer heat could lead to improved electronics
Jan25-08, 05:23 PM   #2
Recognitions:
Gold Membership Gold Member
Retired Staff Staff Emeritus
It isn't possible to simply calculate it, knowing only the densities of the two pure elements. Each compound can form crystals, sometimes many different kinds of crystals, and each will have its own density.
- Warren
Jan25-08, 05:49 PM   #3
an how we could calculate it? is there an equation? the density of SiO2 = ????
Jan25-08, 05:51 PM   #4
density of SiO2
to creat a film of alloy Al and Ti we use to flux of each element and a substrat.
if the flux of Al is double of that of Ti, then we obtain an alloy on the substrat AlTi or what???
Jan25-08, 06:14 PM   #5
Recognitions:
Quote by physicist888 View Post
Try google. Also, SiO2 is so common that the density is listed in most tables of material properties.
Jan25-08, 06:23 PM   #6
i know the value, but i need to know how to calculate it
Jan25-08, 06:29 PM   #7
Recognitions:
Didn't I already say that you cannot calculate it only by knowing the density of Si alone and O alone?
- Warren
Jan25-08, 06:37 PM   #8
then which other values do we need to calculate it??
Jan25-08, 06:41 PM   #9
Recognitions:
You need to know its bond angles and lengths, crystal organization, etc.
- Warren
Jan25-08, 06:47 PM   #10
and you dont know about the other question??
((to creat a film of alloy Al and Ti we use to flux of each element and a substrat.
if the flux of Al is double of that of Ti, then we obtain an alloy on the substrat AlTi or what???))
Jan25-08, 08:53 PM   #11
Recognitions:
Also almost impossible to answer. What kind of film you end up will depend on many different parameters (including deposition parameters such as temperature, pressure etc). My guess would be that you would end up with a granular film with grains of Al and Ti (Al tends to form small grains so the film might even be quite dense).
But again, that is only a guess.
In order to calculate something like that you would need a reasonably good supercomputer and extensive knowledge of DFT calculations
Mar3-08, 05:06 AM   #12
would it be possible to calculate the density of SiO2 just from the following:
(1) Cell vectors of Unit cell (ie. Volume)
(2) Formula Units per unit cell. (ie. Mass of the atoms in the unit cell)
Thread Closed
Thread Tools
Similar Threads for: density of SiO2
Thread Forum Replies
Spectrometry-SiO2-need help Chemistry 7
calculating the redshift at which radiation energy density equaled mass density Cosmology 4
Amorphous SiO2 reaction Chemistry 2
Amorphous SiO2 reaction Atomic, Solid State, Comp. Physics 0
SiO2 questions plz Atomic, Solid State, Comp. Physics 1
