Physics Forums Logo
* Register * Upgrade Blogs Library Staff Rules Mark Forums Read
image   image
image Speed of the pendulum bob? Share It Thread Tools Search this Thread image
Old Jan30-08, 12:17 PM                  #1
looi76
looi76 is Offline:
A simple pendulum consisting of a small heavy bob attached to a light string of length 40cm is released from rest with the string at 60 degrees to the downwards vertical. Find the speed of the pendulum as it passed through its lowest point.
2. Relevant equations
Can't find an equation which is related to the question.
3. The attempt at a solution
Old Jan30-08, 12:25 PM                  #2
Doc Al
PF Mentor
Doc Al's Avatar
Doc Al is Offline:
Don't look for "equations", look for applicable principles. You can try to analyze the forces acting on the pendulum and apply Newton's laws (the hard way) or you can look for a conservation law that applies (the easy way).
Old Jan30-08, 01:42 PM                  #3
looi76
looi76 is Offline:
x = 40/cos60
x = 80*10^-2 m
v = √(2gh)
v = √(2*10*80*10^-2)
v = 4ms^-1
but the answer in the text book is 2ms^-1
Old Jan30-08, 01:48 PM                  #4
Doc Al
PF Mentor
Doc Al's Avatar
Doc Al is Offline:
Originally Posted by looi76 View Post
x = 40/cos60
x = 80*10^-2 m
This caculation for the change in height of the bob is incorrect. Draw yourself a diagram showing the initial and final positions of the bob and recalculate the initial height.
Old Jan30-08, 01:54 PM                  #5
looi76
looi76 is Offline:
Thanks Doc Al
x = cos60*40
x = 20*10^-2m
v = √(2gh)
v = √(2*10*20*10^-2)
v = 2ms^-1
Old Jan30-08, 02:13 PM                  #6
Doc Al
PF Mentor
Doc Al's Avatar
Doc Al is Offline:
Very good, but be careful:
x = cos60*40
x = 20*10^-2m
cos60*40 is the vertical distance below the pivot point. To find the change in height, you must subtract this from the length of the string. Luckily, 40 - 20 = 20.
(What if the angle was 30 degrees instead of 60?)
Old Jan30-08, 02:26 PM                  #7
looi76
looi76 is Offline:
If the angle was 30 degrees:
x = cos30*40
x = 35
h = 40 - 35
h = 5
v = √(2gh)
v = √(2*10*5*10^-2)
v = 1ms^-1
Right?
Old Jan30-08, 02:31 PM                  #8
Doc Al
PF Mentor
Doc Al's Avatar
Doc Al is Offline:
Excellent!
My only suggestion: Don't round off your calculations until the very last step. (Cos30*40 = 34.64, not 35.)
Old Jan30-08, 02:37 PM                  #9
looi76
looi76 is Offline:
Ok! Thanks...
image image
Reply
Thread Tools
Similar Threads for: Speed of the pendulum bob?
Thread Thread Starter Forum Replies Last Post
How do resistance and speed of a coil in pendulum motion in a magnetic filed affect.. Flame666 Introductory Physics 3 Mar5-08 04:40 PM
bullet and pendulum bob....initial speed...help! momentum. lettertwelve Introductory Physics 3 Dec12-07 07:07 PM
[SOLVED] Pendulum Speed and total ME thatgirlyouknow Introductory Physics 5 Oct17-07 03:26 PM
speed of a pendulum at certain angles bearhug Introductory Physics 1 Oct2-06 02:58 AM
Pendulum Minimum Speed IB Introductory Physics 4 Nov20-05 07:35 PM
Powered by vBulletin Copyright ©2000 - 2010, Jelsoft Enterprises Ltd. © 2009 Physics Forums
Sciam | physorgPhysorg.com Science News Partner
image   image
