What Is the Equilibrium Temperature of Copper in Water?
  • Thread starter Thread starter Dx
The equilibrium temperature of a 270 g block of copper at 300°C placed in a 150 g aluminum calorimeter cup containing 820 g of water at 12°C is approximately 10.02°C. The correct formula for calculating heat transfer is Q1 = Q2, where Q1 represents the heat lost by the copper and Q2 represents the heat gained by the water and calorimeter. The specific heat capacities used are 0.385 J/g°C for copper and 4.18 J/g°C for water. The initial calculation of 20.2°C was incorrect due to the omission of the aluminum's heat capacity in the equation.
  • Understanding of heat transfer principles
  • Familiarity with specific heat capacity
  • Basic algebra for solving equations
  • Knowledge of calorimetry
  • Review the concept of heat transfer in calorimetry
  • Learn about specific heat capacities of various materials
  • Practice solving calorimetry problems involving multiple substances
  • Explore advanced topics in thermodynamics
Students in physics or chemistry, educators teaching thermodynamics, and anyone interested in understanding heat transfer in calorimetry scenarios.
Dx
Hello,
what will be the equilibrium temperature when a 270 g block of copper at 300 degrees C is placed in a 150 g Al calorimeter cup containing 820 g of water at 12 degree C?
My answer is 20.2 C Is this correct?
I done is like so 270 * (390)*(300-T) = (820)*(900)(T-12) sorry but i forgot where I referenced this formula, I think i am confused with this problem though. It doesn't seem right to me so i thought i would ask?
Thanks!
Dx
:wink:
The formula is:
Heat lost by copper = Heat gained by water
Where the heat (q) transferred to/from a body is given by:
q=mC(Thot-Tcold)
m=mass
C=specific heat
Thot=higher temp
Tcold=lower temp
The problem with your solution is that you need:
Heat lost by copper = Heat gained by water and aluminum[/color]
If you include the aluminum, you will get this right.
Hi there,
The equilibrium temperature in this scenario can be calculated using the formula for heat transfer between two objects:
Q1 = Q2
Where Q1 is the heat lost by the copper block and Q2 is the heat gained by the water and calorimeter. We can set up the equation as follows:
(270g)(0.385 J/g°C)(300°C - T) = (820g)(4.18 J/g°C)(T - 12°C)
Simplifying, we get:
103.95(300 - T) = 3427.6(T - 12)
30985.5 - 103.95T = 3427.6T - 41131.2
35399.3 = 3531.55T
T = 10.02°C
So the equilibrium temperature is approximately 10.02°C, not 20.2°C as you calculated. I suggest double-checking your calculations and the formula you used. I hope this helps! Good luck with your studies.
23K
