How Far from the Midpoint is the First Point of Constructive Interference?
The problem involves two in-phase loudspeakers positioned 2.55 m apart, emitting sound at a frequency of 370.0 Hz. A microphone is placed midway between the speakers and moved to find the first point of constructive interference. The speed of sound in air is given as 340 m/s.
  • Participants discuss calculating the wavelength using the speed of sound and frequency. There is an exploration of the conditions for constructive interference, particularly the path difference relative to the wavelength. Some participants question how to accurately determine the distance from the midpoint to the point of constructive interference.
Multiple interpretations of the distance from the midpoint to the first point of constructive interference are being explored. Some participants suggest different calculations and reasoning, but there is no explicit consensus on the correct approach or answer at this stage.
Participants are navigating through the implications of the path difference and its relationship to the wavelength, while also addressing the specific request of the problem regarding the distance from the midpoint.
moronto
Two in-phase loudspeakers are 2.55 m apart. They emit sound with a frequency of 370.0 Hz. A microphone is placed half-way between the speakers and then moved along the line joining the two speakers until the first point of constructive interference is found. At what distance from that midpoint is that first point? The speed of sound in air is 340 m/s
λ = v/f
Ok, so first thing is to find the wavelength, v/f = 340/370 = 0.919m
What is wanted is constructive interference, so the path difference/λ should be a whole number, and the first point of constructive interference would be when path difference/λ = 1.
Now the midpoint between the two speakers is 2.55/2 = 1.275m.
Not really sure how to put it all together.
Since you're solving for the distance between the central maximum and the first order maximum, [tex]L = \lambda[/tex].
1.275-0.919=0.356 will be distance from midpoint to point in which became interference.
No, the first constructive interference will occur 0.919 m from the midpoint.
I've actually tried both those answers and they didnt work.
I tried 2.55-0.919 = 1.63 then subtracted the midpoint, 1.275 from it, = 0.356m
The question is asking for the distance from the midpoint. Your final answer would be 0.919 m.
  • · Replies 20 ·
  • · Replies 19 ·
