Solving Linear Algebra Problem: Eliminating p_2 with Diagonal D
The discussion focuses on solving a linear algebra problem involving the elimination of variable p_2 from a system of equations represented by a block matrix. The matrix includes diagonal matrices V and D, with the key insight being that the diagonal nature of D allows for straightforward elimination of p_2. The solution involves using the inverse of D to express p_2 in terms of known quantities, simplifying the system to solve for p_1 alone. This method leverages the properties of diagonal matrices to streamline the computation.
  • Understanding of block matrix operations
  • Familiarity with diagonal matrices and their properties
  • Knowledge of matrix inversion, specifically for diagonal matrices
  • Proficiency in solving linear systems of equations
  • Study the properties of diagonal matrices and their inverses
  • Learn about block matrix decomposition techniques
  • Explore methods for solving linear systems using matrix factorizations
  • Investigate applications of linear algebra in optimization problems
Mathematicians, data scientists, and engineers involved in linear algebra, particularly those working on optimization and system solving in computational mathematics.
hotvette
I have a book that goes though a detailed development of the following:
[tex]\left[\begin{matrix}J^TJ & J^TV\\ VJ & D \end{matrix}\right]\left[\begin{matrix}p_1 \\ p_2\end{matrix}\right] = \left[\begin{matrix}J^Tr\\ Vr + Ds \end{matrix}\right][/tex]
where V and D are diagonal matrices and everything is known except [itex]p_1[/itex] and [itex]p_2[/itex].
Then it says "since the lower right submatrix D is diagonal, it is easy to eliminate [itex]p_2[/itex] from this system and obtain a smaller n x n system to be solved for [itex]p_1[/itex] alone." The implication is that it's so easy, explanation isn't needed. However, I don't see it.
Can someone explain how to eliminate [itex]p_2[/itex] given D is diagonal?
I've managed to come up with:
[tex][VJ(J^TJ)^{-1}J^TV - D]p_2 = VJ(J^TJ)^{-1}J^Tr - Vr - Ds[/tex]
but this seems far more complicated than what is implied and I don't see how D being diagonal simplifies anything.
If [itex]D[/itex] is diagonal with non zero eigenvalues, then it has an inverse [itex]D^{-1}[/itex]. Thus from
[tex]V\,J\,p_1+D\,p_2=V\,r+D\,s[/tex]
you can solve for [itex]p_2[/itex], i.e.
[tex]p_2=D^{-1}\,(V\,r+D\,s)-D^{-1}\,V\,J\,p_1[/tex]
and use this to eliminate [itex]p_2[/itex] from the other equation.
Thanks. I can't believe I didn't see it. So simple.
