What is the moment of inertia of a sphere?
The discussion revolves around deriving the moment of inertia of a sphere about an axis through its center of mass. Participants are exploring various methods and attempting to understand the underlying concepts related to the moment of inertia.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants discuss using integration techniques to derive the moment of inertia, with some attempting to use thin disks and others considering spherical shells. Questions arise regarding the correctness of their approaches and the definitions of variables used in the calculations.
There is an ongoing exploration of different methods to derive the moment of inertia, with some participants providing guidance on potential approaches. However, there is no explicit consensus on a single method, and various interpretations of the problem are being examined.
Some participants express confusion regarding the application of formulas and the definitions of variables, indicating potential misunderstandings in the setup of the problem. Additionally, there are references to homework constraints that may affect the approaches taken.
Oerg
Ok, so i was trying to derive the moment of inertia about an axis that runs through the centre of mass of the sphere and i couldn't get the answer of [tex]I_{CM}=\frac{2}{5}MR^2[/tex]
The moment of inertia is defined as
[tex]\int r^2dm[/tex]
and since
[tex]dm=\rho \times 4\pi r^2\times dr[/tex]
so
[tex]I_{CM}=\int_{0}^{R}4\rho r^4 \pi dr[/tex]
[tex]I_{CM}=\frac{4\rho\pi R^5}{5}[/tex]
and expanding rho gives
[tex]I_{CM}=\frac{3}{5}R^2M[/tex]
which is not correct.
the typical way to derive the moment of inertia of a sphere is to use the result for the moment of inertia of a thin disk (axis through center). The sphere is just a collection of thin disks with different radius...
Hmm, then is there something wrong with my working? I would like to know in case I have some conceptual misunderstanding.
looks like you were trying to add up contribution from many many thin spherical shell (of radius r) but u haven't used the moment of inertia for shell. remember the "r^2" in the moment of inertia formula represents the perpendicular distance from axis of rotation to the point mass with mass m
personally, i would do this problem by
first MoI of thin hood
then MoI of thin disk
then MoI of sphere
or the hood->shell->sphere path
oh man pelase help me I am going crazy
so i decided to try solving using the disk method
[tex]\int r^2 dm[/tex]
so
[tex]dm= \rho \times \pi r^2 \times dr[/tex]
and
[tex]I_{CM}=\int_{0}^{R} \frac{M}{V} \pi r^4 dr[/tex]
and the moment of inertia of half a sphere is then
[tex]I_{CM}\frac{=3MR^2}{20}[/tex]
and this moment of inertia of half a sphere obviously doesn't give the moment of inertia of a sphere HELP!
Assuming you know how to derive the disk, let's use that result
here I sliced the sphere into many disks with different radius
see attachment
I found another post here on how to derive it but it is suggested that you try it yourself a bunch of times...
This [itex]r[/itex] refers to the distance from the rotational axis ...
and this [itex]r[/itex] refers to the distance from the center of the sphere. You got an erroneous result by erroneously equating two very different measures that happen to have the same symbol.
Rather than integrating over a series of spherical shells I suggest you look at integrating over a series of cylindrical shells. The height (and hence mass) of these shells will vary with the radial distance from the axis of rotation. It will help to remember the formula for the length of a chord length of a circle as a function of the radius and chord angle ...
The [tex]dm=\rho \times 4\pi r^2\times dr[/tex] doesn't work. If you were to cut the sphere in half and try to straighten out one of the halves, it won't work out too well and that's probably the source of the mistake.
thanks for the replies, i finally figured how to derive it on my own. The moment of inertia of a disk is
[tex]I_{CM}=\int_{0}^{R} r^2 \times \rho \times 2 \pi r \times dr[/tex]
[tex]I_{CM}=\frac{MR^2}{2}[/tex]
Integrating these differential moment of inertia gives us the moment of inertia of a sphere
[tex]dI=\frac{r^2}{2} dm[/tex]
[tex]dm=\rho \times \pi r^2 \times dz[/tex]
So the integral becomes
[tex]I=\int_{-R}^{ R} \frac{\rho \pi}{2} (R^2-z^2)^2dz[/tex]
[tex]I=\frac{2}{5} MR^2[/tex]
  • · Replies 17 ·
18K
